Yes or no?!
Old Sep 21, 2006 | 06:41 AM
Dstranks's Avatar
Default Yes or no?!
based upon my mods do you think i should get a n75 j valve on my car? If I do will i really notice the difference? right now i peak at about 19-20 psi on my giac chip and it drops to about 15-16 psi but sometimes when i redline 3rd or 4th gear to stock redline the chip disengages and everything goes back to stock feel and my boost drops down to max of about 8 psi. I dont know what to do in this situation... I have to just restart my car. Will the n75 j valve fix that?
Old Sep 21, 2006 | 09:45 AM
david9999's Avatar
Default RE: Yes or no?!
Doubt it will. Sounds like your car is going into overboost.
Old Sep 21, 2006 | 11:15 AM
quattrosedan's Avatar
No it wont, like david9999 said, it sounds like your car is overboosting already. So why would running a couple more pounds on top of that help? Save up and go with a fmic. You are way out of the efficiency of the ko3 at 20 psi, so you are just blowing hot air.
Old Sep 21, 2006 | 07:22 PM
Adam@mvp's Avatar
a FMIC would be good and you will get more HP and see a difference and be able to maintain your boost way better
Old Sep 21, 2006 | 07:28 PM
fher7096's Avatar
WOW 19-20 with just a chip. I thought it was only supposed to be 17 max. Well anyways the n75j valve made a 1.5psi change in my B6. I boost to about 18.5-19 and hold 12psi to redline. I really noticed a difference in power so I would highly suggest you get one after you figure out what is going on with the overboosting.
