Yet another HID question...
I've been looking around for a good set of HID's for my 07 A4 (currently halogen headlamps) and have come across a few promising brands.
After looking around I see that some brands are claimingthat other brandswill set off theheadlamp warning lamp in the dash. Is this true? If so can anyone recommend a HID brand that will notdo this.
I've alreadysearched the HID posts and didn't see anything that addresses this issue. If I missed it, please link me
I am not sure but I think you can get away with just a plugg n play kit. It might not set off thebulb out light. HOWEVER, that issue was resolved when someone figured out that if you ad a resistor it will doop the ecu and you won't throw a light.
https://www.audiforums.com/m_27324/tm.htm
even better thread (page 4, last post so far), contains a visual aid to the bulb out solution.
https://www.audiforums.com/m_371917/mpage_4/key_/tm.htm
The warning light comes on because the difference in wattage from using plain halogen to using HIDS. All you have to do is stick a 2.2k Ohm Resistor that you can get from radio shack into the car's stock harness. (Where you plug in the two wires from the HID bulb into the stock harness, just shove a resistor in there.) It will work fine.
well i just installed a vision bulbs kit and put the resistor in and i get no bulb out and they work perfect i love them. But finding a place to mount the Ignitor boxes was a bitch wow i toook me like 3+hours to install the kit!!
ORIGINAL: AlbozA4
cost me 300, because the shop I went to had to take out all my old ballasts and what not, drill holes in my housing and fill it with some sort of apoxy, not to mention they had to take off the front end.
I posted some pics of my lights in another thread.
page 4
page 4
