$2900 Tiptronic transmission help
Old Apr 22, 2010 | 03:17 PM
bigched's Avatar
Ya that was the first thing I checked was the oil level but it was ok. Didn't take the rad of to fix the front end
All it was. The fender left side hood light and bumper. The valve body was replied buy the shop. And now as sun as I start the car and put it in gear it go`` in to limp mode.
Old Apr 22, 2010 | 04:44 PM
nemohm's Avatar
Replacing the valve body requires pan open and new fluid - what was it, what quantity, how the level was adjusted?
Do you have a way to pull the DTC?
Limp mode is 3 rd geaar only - is this your case?
Do you have a reverse?
Old Apr 22, 2010 | 06:58 PM
bigched's Avatar
whats a DTC? ya i has reverse. it has to be 3th cuss it gos very slow. but i don't drive on it. guest move it a little. and the fluid level was checked at the shop.
Old Apr 24, 2010 | 12:44 PM
bigched's Avatar
ya i was thinking of taking it to the dealer but is there any shop one or you gays can recommend. instead of wasting all that money at the dealer. now the tranny dos not slip it goes in to limp mode *** son as i put it in drive.
Old Apr 24, 2010 | 03:45 PM
mystrodo's Avatar
Do you call $80hr at Audi compared to $79hr at Joe's garage a waste of money?
You payed someone $2900 to rebuild your trannie and it's not fixed, did you have Audi do a diagnostic on the transmission *before you took it to a non-Audi shop? I'd say your priorities are way off since you think factory trained Audi experts are a waste of money especially when you have real issues which you obviously have. You may not of even needed a rebuild.
Old Apr 24, 2010 | 08:04 PM
bigched's Avatar
Angry
tranny need a rebuilt had wear on some gears. don't know Wat there called but i opened the tranny to inspect before i toke it to the shop. cuz i wanted to have a warranty sins the rebuild kit is like $750. plus the the gears. And Prestige Audi charge $135 an hour. if the dealer charge $80 then it wood have went there first. the man seas minimum 3 hours to diagnose it. but looks like it going to end up there any way. thought the Audi forum cod lead me in the right direction.
Old Apr 25, 2010 | 10:23 AM
jhuffman's Avatar
umm Are you in Colorado? In denver there is a place called prestige audi but I know of several other good shops that I would highly recommend to you.
Old Apr 25, 2010 | 01:07 PM
  #18
mystrodo's Avatar
I understand your frustration...sorry. Where do you live and maybe the forum can offer some alternatives close to your home. Also, the person who did your rebuild has some serious responsibility that the job be completed correctly.
Old Apr 25, 2010 | 03:54 PM
  #19
bigched's Avatar
im located in Denver. but the tranny shop will take responsibility for the tranny but he seas the ecu in not programed or some thing that that's one of the ecu codes it throwing. have to git that taken care. to see if that making the tranny go in to limp mode.
Old Apr 25, 2010 | 04:41 PM
  #20
jhuffman's Avatar
When my car needs work I take it to a place called elder auto. I highly recommend to anyone. There is also a audi trained specialist who owns a small independant in south denver, I'm trying to remember his name. If its something electrical or with the ECU take it to him and he will help you out.
