01 2.7T Slow oil leak from filter
Old Jan 1, 2010 | 07:30 PM
6605stang's Avatar
Default 01 2.7T Slow oil leak from filter
So I changed the oil for the first time in our high mileage 2001 Audi A6 2.7T and after applying the Mann Oil Filter (with a small amount of oil to the gasket), filling with around 7 qts of Mobil 1 Syn... there appears to be a very slow leak from the oil filter gasket. Anyone ever had this problem? I hate to have to drain the oil out considering I just put $45 worth of oil in it.
Any suggestion?
Old Jan 1, 2010 | 08:40 PM
a6hcw's Avatar
The leak may be coming from the gasket between the engine and the oil cooler, instead of from the oil filter gasket. Check that your filter is hand tight.
Old Jan 1, 2010 | 09:25 PM
Coors's Avatar
Any suggestion?
Are you 100% sure it's the filter that's leaking? Maybe something is leaking down onto it. I had a valve cover leak that would drip down onto the filter.
Threw me off when I went to change the oil filter. I initially thought the same thing as you. Turns out it was a V C gasket.
How did yo tighten the filter? By hand or with a wrench?
Old Jan 1, 2010 | 09:53 PM
NH_USA's Avatar
That little O-ring between the cooler and engine almost caused me to loose a motor --- But thats another story..
fI you used a bit of oil on the filter gasket and made sure the surface was clean I'd try to tighten the filter a bit more. I usually give it about a 1/3 turn once the gasket seats.
Old Jan 1, 2010 | 09:59 PM
chefro's Avatar
^^^ everyone + 1
Since buying the car last year I changed the oil two times - Mann Extended Life filters. Both times I tightened them by hand and had/have no leaking issues.
As the guys said, recheck the filter for tightness or look elswhere for the leak.
Old Jan 2, 2010 | 04:16 PM
Lscheres's Avatar
So mann oil filters are required?
Old Jan 2, 2010 | 08:18 PM
6605stang's Avatar
Thank you all for your replies. I'm a bit embarrassed to say that I think I found the problem.
I generally do not put oil in the filter before replacing it, but this time I figured I start and may have put a bit too much in so that when I tilted it sideways to spin it on, a little must have dripped out beyond the gasket before it sealed. I probably wiped off a total of about 3-4 droplets (with none dropping on the ground) and now it's not coming any more. I think what I was seeing was probably just the spillage before the gasket sat.
I did hand tighten the filter, but I tightened it very hand tight. Probably more than I should have, but I thought it was leaking.
And I don't think Mann filters are required, but I'm super paranoid of repairs on this thing so I decided to use the same air and oil filters that car has been used to its whole life.
And to those speaking of other leaks, I'm pretty certain it wasn't something else leaking as the underside is virtually oil free so it doesn't look like there has ever been any prior leakage or blowoff.
Thanks all for the replies and sorry for wasting your time. I feel like an idiot for not realizing what it was until now.
Old Jan 2, 2010 | 09:15 PM
NH_USA's Avatar
I wouldn"t say that Mann filters are required but they are all I use because I have heard horror stories when people use something else.. I once heard some say that it was OK to use any filter on a Audi as long as it was black.
Chefro - Painting a yellow Penzoil filter black is not allowed!
Old Jan 3, 2010 | 04:27 AM
chefro's Avatar
Actually I painted black a Motorcraft filter, since it is about the same size as a Mann extended... SHHHHHHHHH, don't tell anyone!
Old Jan 5, 2010 | 08:58 AM
NH_USA's Avatar
Motorcraft?? from Fix Or Repair Daily?? You certainly like to live dangerously!
