03 Audi A6 3.0 Jerks into reverse
Old Sep 6, 2007 | 09:23 PM
03AudiA6's Avatar
Default 03 Audi A6 3.0 Jerks into reverse
I have a 2003 Audi A6 3.0 that sometimes, not more than once a week and I drive it every day, jerks when I put it into reverse. It jumps about three or four times and then goes into gear. It does not do this in any other gear and besides a little hesitation when I put my foot on the gas from a stopped position, I am guessing that it just the gears kicking in, there are no other signs of any tranny problems. I think there is a belt instead of the traditional gears. Is this normal or should I be concerned? Please help because this is my first Audi and I LOVE the car. Thank you.
Old Sep 7, 2007 | 10:19 AM
slee22's Avatar
Default RE: 03 Audi A6 3.0 Jerks into reverse
Is it FWD? If so then you have the CVT tranny which uses belts...about the jerking: mine does it as well but only if I'm in a hurry and put it in reverse too quickly after I start the car.
Old Oct 24, 2007 | 08:17 PM
dhallig's Avatar
I have the same car/problems. Did you ever get it looked at? If so, was there a solution or is it a "live with it" solution?
Old Oct 24, 2007 | 10:37 PM
dankhound's Avatar
Ive seen this problem a few times and unfortunatly whether cvt or automatic there is something mechanical inside the trans that causes the failure, which results in a new trans being installed. My best advice, Use reverse as little as possible to conserve the life of your reverse gear.
Old Dec 26, 2007 | 04:51 PM
Tha H.N.I.C's Avatar
If you are still interested in this issue, I had a 1993 Saturn that did the same thing. Ihad the Saturn dealershiptake a look at it to see what the problem was and theytold me that one of the transmission gaskets were bad. This may be that case with you.
Audeeznuts
Nov 25, 2013 06:23 PM
jmcnab57
Sep 3, 2013 01:09 PM
