'04 2.7T noise when cold
Old Oct 23, 2007 | 08:35 PM
ctfeet's Avatar
Default '04 2.7T noise when cold
Hi,
I just bought a 2004 A6 2.7T about a month ago. I have noticed that when I start it from cold it makes
a noise similar to an exhaust leak. It only lasts for a minute or two and then sounds normal. Is this normal
for this car or is it an exhaust leak? I was thinking something wasn't sealing properly when cold but would
seal itself after slight warm-up. I don't know if I should bring this in for service or not.
Any help would be appreciated.
Thanks
Stan
Old Oct 23, 2007 | 09:31 PM
funpig's Avatar
Member
Default RE: '04 2.7T noise when cold
Hello,
My 2004 Allroad 2.7T has always done this and it seems to be normal. I believe my 2000 S4 did it also.
Old Nov 1, 2007 | 01:09 PM
JCMAC's Avatar
That noise you are referring to is most likely from the operaton of thesecondary air injection pump.It normally operates for less than 2 minutes immediately after a cold start. Its purpose is to start the warm up of the exhaust catalytic converters soonerby injecting fresh air into the exhaust system before the pre-cats thus adding more oxygen into the exhaust gas stream via a one way 'combi valve'attached tothe cylinder heads at the rear of the motor.
Enjoy!
Old Nov 1, 2007 | 01:14 PM
formulagigi's Avatar
the three 2.7T I have driven all do it. Tjis engine is real rough when cold and sounds like a tractor but I love it!!!
Avant Fan
B8 Models
13
Nov 13, 2014 02:33 AM
muzhao
B7 Models
10
Feb 24, 2013 10:53 AM
Wilkinson
B8 Models
Jan 25, 2010 10:58 PM
cary12
Dec 2, 2006 02:53 PM
beefski
Nov 25, 2005 04:51 PM
