100k maint. on 01 4.2? ***NOOB WARNING***
Old Feb 22, 2008 | 01:44 AM
iMannyAM321's Avatar
Member
Default 100k maint. on 01 4.2? ***NOOB WARNING***
i did a few searches and couldn't really find what I was looking for.
I just went over 100k and need to get maint. done on the car. Could you fellas clue me in on everything I would want to get looked at/changed.
I plan on doing the TB and everything(don't know everything I should get done at that time either), so if you could help me with that it would be greatly appreciated. I will do a search for that in a few days though.
judging from the service manual that has the intervals, i guess I am looking at getting everything done at the 10k and 20k mark.
Maint at 10k
Engine: change oil
Oil filter: Replace
Cooling system: check coolant level
Exhaust system: check for damage and leaks
Engine: On Board Diagnostic test
Doors: Lubricate door hinge mechanism (did this today acually)
Battery: Check electrolyte leve and add if necessary
Windshield wiper and washer: check fluid leve and add if necessary
Automatic Shift lock: check operation including park/neutral switch
Tires and Spare wheel: check condition and pressure (rotate also I can assume)
Brake System: Check for damage and leaks, thickness of pads and brake fluid level
Drive shafts: check boots
Road test: check braking, kick-down, steering, electrical, heating and ventilation systems, AC and power accessories
Service reminder indicator display: reset
Lights: check
Maint at 20k
Front axle: check dust seals on ball joints and tie rod ends, check tie rods
Haladex Clutch:Change Oil and filter
Auto Transmission: check for leaks
Transmission final drive: check oil level, add if necessary
Dust and pollen filter: Replace
Head lights: adjust
If anyone actually reads this, thanks for looking. I copied that from the manual i have. Please let me know if you know anything I missed just to be safe. I am going to get the Bentley manual and look into doing all of this myself in the future, just right now I don't have the time. At the least I need to learn how to change the oil in this beast.
Old Feb 22, 2008 | 05:22 AM
Kevin's Avatar
Default RE: 100k maint. on 01 4.2? ***NOOB WARNING***
Here is the list of what I think should be done at 100k. The biggest thing you are missing from your list is the timng belt. In addition, as long as you are having the timing belt done you should also have the water pump done.
1. Engine Oil / Oil Filter: Change oil and replace oil filter
2. Cooling System: Check coolant level. Add coolant if necessary.
3. Exhaust System: Check for damage and leaks.
4. Engine, On-Board Diagnostic: Check Diagnostic Trouble Code Memory.
Purge if necessary.
5. Engine: Check for leaks
6. Air cleaner: Clean housing and replace filter element
7. Snow screen for air cleaner: Clean
8. Battery: Check electrolyte level. Add if necessary
9. Dust and pollen filter: Replace
10. Manual transmission and final drive: Check for leaks
11. Automatic transmission and final drive: Check for leaks
12. Sunroof: Clean guide rails and lubricate
13. Haldex clutch: Change oil and filter
14. Windshield Wiper and Washer / Headlight washer: Check adjustment and
15. function check fluid level and add if necessary.
16. Wiper arm pivot points: Lubricate
17. Tires and Spare Wheel: Check for wear and damage. Check pressure.
18. Tire repair set: Check renewal date.
19. Service Reminder Indicator Display: Reset display.
20. Lights: Check the lights. Check Headlight adjustment
21. Brake System: Check for damage and leaks. Check thickness of pads and brake fluid level.
22. Drive Shafts: Check boots.
23. Doors: Lubricate door hinge mechanism.
24. Trunk hinges: Lubricate trunk hinge mechanism
25. Visual Check: Check undercarriage for damage
26. Power steering: Check fluid level
27. Spark plugs: Replace
28. Continuously variable transmission (multitronicâ„¢): Change ATF
29. Ribbed belt: Replace
30. Timing belt and timing belt tensioning system: Replace
31. Timing belt: Replace
32. Front and Rear Axle: Check excessive play
33. Front and Rear Axle: Check dust seals on ball joints and tie rod ends. Check tie rods
34. Direct shift gearbox (DSG): Change oil and replace filter element
35. Road Test: Check braking, kick-down, steering, electrical, heating & ventilation
36. systems, air conditioning, Automatic Shift Lock (ASL) operation and power accessories
Old Feb 22, 2008 | 05:49 PM
ppgoal's Avatar
The timing belt is critical - do it soon. Change the TB, water pump, tensioners, thermostat, antifreeze, and serpentine at the same time. A good source is www.blauparts.com. They sell a complete kit less one tensioner, but included antifreeze. There are a couple similar sources that are probably equally good. Make sure the water pump has ametal impeller.
When I replaced my clutch and flywheel at 89k, I also had them replace the transmission, tranfer case, and rear differential fluids. Otherwise it's been Mobil1 oil and filter every 7-8k and cleaning/re-oiling the K&N every 20k.
I'm just under 114k with no recent problems.
Old Feb 22, 2008 | 10:04 PM
Member
Whether or not I get the timing belt done at the same time depends on my funds when I go. If I do the 100k in a week, ill have to just do the 100k. If I wait 2 or 3 weeks, I will be able to get it all done, which would be preferrable.
Thanks so much Kevin and ppgoal for your input.
I just got a quote from my dads mechanic, who just did an A6 timing belt a week ago. it was $800 for labor, doesn't have prices on the parts yet. I dont know why if he just did it recently... I think he will let me buy the parts though. I am going to go see him tomorrow and see what he says.
Old Mar 1, 2008 | 09:58 AM
katcoota's Avatar
Maybe I missed this, but shouldn't the brake fluid be replaced if it has never been done? Suggested replacement interval is 2 years regardless of mileage.
I would also suggest changing the fuel filter at 20 bucks for the part. Generally this is not listed as a service part, but worth it.
Also worth getting your fuel injectors cleaned.
Old Mar 1, 2008 | 11:29 AM
formulagigi's Avatar
Bentelys web site has Adobe files of required service for each model. Check them out
Old Mar 4, 2008 | 07:55 PM
Member
I think im going to be getting a kit from blauparts. The only thing that is confusing me is where it says the kit you need depends on the VIN number... either
2001-2004 A6 Sedan - Quattro w/ 4.2L 8 Cylinder 40 Valve Engine Code AWN > Starting with Vin 105001
or
2000-2001 A6 Sedan - Quattro w/ 4.2L 8 Cylinder 40 Valve Engine Code AWN > Starting with Vin 130001 and up to Vin 105000
My VIN ends in 132148. I may be really tired but looks like i don't fit in either of them.
ORIGINAL: ppgoal
The timing belt is critical - do it soon. Change the TB, water pump, tensioners, thermostat, antifreeze, and serpentine at the same time. A good source is www.blauparts.com. They sell a complete kit less one tensioner, but included antifreeze. There are a couple similar sources that are probably equally good. Make sure the water pump has a metal impeller.
Old Mar 4, 2008 | 09:49 PM
frankinstyn's Avatar
ORIGINAL: iMannyAM321
or
I'm betting that mileage is a typo. Thinking it should be 150000 and 150001.
Old Mar 8, 2008 | 07:54 AM
RedShoeRider's Avatar
ORIGINAL: ppgoal
I second the blauparts.com idea. I just did the timing belt on my woman's A4, and their kit was great. Spend the extra 30 or so bucks to get the toolkit along with the complete kit....it's very well worth the money! The tensioner is an extra 80 bucks or so The instructions they send with the kit are...well....sorta useless. They're ok, but there are far better instructions here online.
Old Mar 8, 2008 | 01:06 PM
NH_USA's Avatar
or
There is a good chance that I missed that day in school butisn't 132148more than 130001 andisn't 105001 less than 130001?
I suspect they mean 2000 - 2001 up to 105000
and 2001 - 2004 from 105001 thru 130000.
Your vehicle comes after 130000 so I would look at 2004-2005 for the kit.
Call Chris Semple at Force Five Automotive in Concord NH 603 223-6700 and see if he can suply the kit you need.
