15 common faults
was doing some research and found this however i couldnt find an answer so does anyone know the 15 common faults or wear items that you should check for on the a6 ?
- 0 area(s) on the bodywork to inspect - 3 engine check(s) to make - 1 wear item(s) to spot on the suspension - 4 interior item(s) that you need to ensure work - 7 official recall(s) that should have been completed |
RE: 15 common faults
anyone?
Get a full inspection on any vehicle you intend to buy. Dont even worry about 15 stupid points. Theres alot of things that can be wrong with any vehicle.
ive allready got an audi just wondered if anyone knew so i could know what to look out for
I had to repace control arms on my 98 A6. There was a recall on 1998 and maybe other years I think for two of the control arms.
I had a window motor go out. The trip display usually goes bad. The auto dimming fluid on the side mirrors has leaked out. I have seen this on VW Jettas also. |
