1995 AUDI A6 Instrument Cluster light replace
Old Jun 20, 2009 | 10:03 PM
cokecain's Avatar
Red face 1995 AUDI A6 Instrument Cluster light replace
Hi I have a 1995 audi a6 and onboard computer light doesnt work anymore, it used to work when i used to hit it ><!
Can someone help me how to fix this or how to replace this please.
Thanks in advance
Old Jun 21, 2009 | 09:20 AM
mcintcmi's Avatar
If it is like my 2001 A6 that has the center display problem. You should remove it and send it in to someplace to get rebuilt. I used Module Masters in Moscow ID. Go to their website and they have removal instructions.
Old Jun 21, 2009 | 07:57 PM
a6hcw's Avatar
You should remove the instrument cluster and remove the bulbs on the back side and chech them with an ohm meter. Usually the bulbs burn out. Sometimes the filament will break so that it intermitently makes contact.
You may either get these special bulbs from the dealer on online from places such as www.AudiCarParts.com. You may google "Audi parts", to find other sources.
There are some bulbs on my 1996 A6 which are soldered to printed circuit boards. The outside temperature sensor and the transmision position indicator bulbs repacements may be purchased at Radio Shack and soldered to these boards.
On the newer Audi, the bulbs may not be easy to replace, but those with the C4 chassis usually unscrew from the cluster.
So you would only need www.modulemaster.com/en/index.php if your instrument cluster had more than burnt out bulbs, such as if the "auto check module" broke. The ModuleMaster removal instructions on their website are not for a 1995 C4 chassis Audi.
Old Jun 24, 2009 | 06:05 PM
cokecain's Avatar
Thank you to mcintcmi and a6hcw.
I did manage to fix it DIY style
All it was to change faulty light lol.
Thank you for your time to reply to my thread
wcshortcakes03
Mar 10, 2008 09:49 PM
mikehh
Feb 11, 2007 01:55 AM
Limmy711
Jan 20, 2006 01:14 AM
pregister
May 3, 2004 04:14 PM
