1998 A6 2.8 Engine Miss while accelerating
Old Jul 22, 2009 | 06:14 PM
patekatek's Avatar
Unhappy 1998 A6 2.8 Engine Miss while accelerating
My "98 A6 Q with 170,000 miles on it just started doing a couple irritating things. A) The engine starts, surges a bit for 10 seconds then idles OK. However, when I put it in gear and press the accelerator nothing happens, no increase in rpm's etc. Just a "dead" pause. In 5 or 10 seconds it then takes off. I had the temp sensor replace last year due to it not starting. I also installed new plugs, checked the air filter, used some SeaFoam but no change. B) About the same time, when driving and with aggressive acceleration, I can feel it miss. Again, all this started at the same time. I have read on this forum about injectors, jumped timing belts, MAF, etc. I HAVE NOT had any check for codes. I also have not changed the fuel filter. I am assuming the fuel pump is in the gas tank and that the round object attached to the outside of the gas tank is the filter.
Any suggestions???????
judgejules95
Nov 29, 2012 12:18 PM
drewsaudi
Sep 24, 2011 01:32 PM
clearon
Dec 10, 2007 07:18 PM
brent07
Aug 10, 2005 02:22 PM
fish16
Jul 18, 2005 05:04 PM
