1999 A6 Quattro
Old Mar 6, 2009 | 12:22 AM
Shwangin's Avatar
Default 1999 A6 Quattro
Heres my new car bought it for 5,000 with 120000. Was this a good buy or not?
Attached Thumbnails 1999 A6 Quattro-27.jpg   1999 A6 Quattro-29.jpg   1999 A6 Quattro-30.jpg   1999 A6 Quattro-31.jpg   1999 A6 Quattro-52.jpg
Old Mar 6, 2009 | 09:31 AM
nm3210's Avatar
What kind of service has been done on it? Has the timing belt at least been changed?? If the previous owner/s kept up the maintenance then it will be a good car for you!
Old Mar 6, 2009 | 03:44 PM
Shwangin's Avatar
Its super clean was in illinois suburbs so im guessing it was taken care of really well. Unsure about the timing belt but i already called my mechanic and he said he would change it for about 500(parts and labor). I dont plan on beating on it, just using it for a daily driver from point a to point b.
Old Mar 6, 2009 | 07:42 PM
NH_USA's Avatar
$500 for parts and labor is a bit low -- I'd make sure it includes changing the water pump, tensioners, and seals when he is in there.
Old Mar 6, 2009 | 08:03 PM
hxgaser's Avatar
Great car! Enjoy it. $500 for a timing belt job with parts and labor is low. Even parts alone, including water pump, thermostat, tensioner, rollers, coolant and etc will run you close to that.
Old Mar 7, 2009 | 02:14 AM
Shwangin's Avatar
alrihgt he said he was just guessing its my dads buddy so it wont be to much more so thats good if i have to change it is there anything else i should be replacing while im replacing? hopefully not need be though. also do you think i over payed for it or was this an alright price cause im just curious on what you guys think
Old Mar 7, 2009 | 02:50 AM
chefro's Avatar
If the powertrain, CATConverters, and muffler(s) are in good shape, then it is a good price since the interior looks clean.
Good find.
Old Mar 7, 2009 | 12:06 PM
NH_USA's Avatar
Shwangin do a search on this forum and see what happens when people just change the TB. Believe me ---do the water pump, thermostat, tensioners and seals when it is apart.
Old Mar 7, 2009 | 02:19 PM
Shwangin's Avatar
Oh thats alright i beleive you gurus on this subject me being a noob on owning an audi. I know that is a lot of stuff to repair but i was just seeing if there was even the littlest thing besides what you guys named off. because i know i dont want to have to take that stuff apart again when i could just avoid anymore problems(by doing everything all at once) that would come up with the engine and components. There is only one real problem and i dont know if it is a problem, The brake light is on is this something i should be concerned about and how would i fix it so its not on?
Old Mar 7, 2009 | 05:20 PM
NH_USA's Avatar
Which brake light?
