1999 A6 Transmission Issues
Hi All. I'm new to the site and have a problem with my A6. To be honest, the A6 2.8 Quattro Tip is a very nice car. haven't had issues with it until I was involved in an accident. Sent the car in and it came out with a transmission problem. Now I'm not sure what to do or what to look for and need some guidance and advice. I'm no mechanic but I'm sure there are loads of peeps here with experience......:)
This is what I am experiencing:
I have been advised by Audi that the TCU has to be replaced. I think it might not be that the TCU is damaged but rather one of the sensors providing bad data. How can I test the TCU? Audi quoted me 12K for a new one. Don't have that kind of money. Somebody else said that the Clutch for the 4th and 5th gear is finished and quoted me 15K to replace it. Has anybody experienced these problems and had them fixed? What did you find was wrong? Any advice or help would be greatly appreciated cause I don't want to lose the car and don't have that much money to replace the TCU or to have the clutch replaced and then to find that that was not the actual problem. |
I would say get the speed sensor first and replace it, since it is shot anyway.
That's fairly cheap - $ 90 at Ariz Autohaus. Replace it and go from there. Is interesting though that both of those codes are not found in the Ross-Tech Wiki. |
According to this document related to 5-speed automatic trannys, a Hydraulic Control E17 is/may be the guilty party...If you can find out what that is.
Thanks guys. I am going to replace the speed sensor over the weekend if I can find one. Will then see how it goes. I'll start searching for info on the Hydraulic Control Valve as well and post back once the speed sensor has been replaced. What is amazing is that one finds posts where people have similar problems but nobody seems to post what their final solution was!!
exactly. Or maybe some of them endup ridding off the car, so they don;t feel like is worth sharing with others anymore... :)
I had a similar problem with my 98 A6 2,4q Tip.
For me it was one of the clutch plates that was worn out do to bad oil/not frequent oil changes. So the solution was either a service on the box, or change it. I found a used one in good condition, and got it changed. |
HI Hagforce. If I may ask, what did you pay for the used box?
It cost me 1200€ :(
