2.7T AWE S-Flo Intake
I was looking around and came across this intake by AWE.
http://www.awe-tuning.com/pages/shar...in&IL=Sflo It looks good and all but I was wondering if anyone has one installed on their 2.7T and if you can tell a difference or not. Thanks, Michael |
RE: 2.7T AWE S-Flo Intake
There is a write up on AW about aftermarket intakes for the b5s4 (2.7) and from what I remember there were some issues with heatsoak. Some opinions stated there was indeed heatsoak, while others argued that the product was helpful. I will try and search for the thread so you can read the info first hand.
http://forums.audiworld.com/s4/msgs/2537351.phtml some opinions on the s-flow |
I think most aftermarket intakes do not work well because it requires the removal of the factory airbox; which the end result will be "heatsoak" and reduced horsepower.
I also think that the "S-FLo" is a little different, because it mounts inside of the factory airbox; which of course will shield and protect from "heatsoak". Whether it adds additional HP, I am unsure, but I could see it helping your car breathe a little better. OOOO |
There is NO HEAT SOAK from the AWE unit. It fits inside the stock airbox.
I noticed better throttle response, & the engine didn't feel flat up top. When logging, I noticed 15 g/s increased flow @ WOT. Since it's in the airbox you don't hear it like other open element filters. |
