2.7t coolant leak after TB change, help please
Old Feb 26, 2011 | 03:14 PM
jonjezak's Avatar
Default 2.7t coolant leak after TB change, help please
delete post
Old Feb 26, 2011 | 03:31 PM
bob martin's Avatar
Good luck and don't rush is all we can say.
Bob
Old Feb 26, 2011 | 04:23 PM
02A6Beau's Avatar
check the area around the thermostat/thermostat housing. I had the same thing happen when I did mine. Started buttoning everything up and added coolant. Had major leakage running down from above the oil pan on the passenger side. turned out I had the t-stat a little cockeyed and the housing didn't seat properly.
good luck
Old Feb 26, 2011 | 05:18 PM
jonjezak's Avatar
Default thanks yall
about to take off the crankshaft dampener then timing belt, have cam lock bar in place. i think it may be the thermostat as well, when i installed it it was a tad bigger( ~1-2mm in diameter than the old one) and didnt want to fit right. i might have to do some custom light filing to the edges to make it perfect and this time i will check for leaks before i put the lock carrier back on.i shined a light under the intake to check the 2nd coolant pump and that looks fine as my car rarely reaches the 248 degree mark, only when im cruisin 85pmh on the freeway for a while. the new water pump gasket looks a littlemoist but nothing major, i will update in a bit
Old Feb 26, 2011 | 08:13 PM
jonjezak's Avatar
Default i'm retarded, thermostat was backwards
yeah i def installed my thermostat the wrong way.i was thinking about it when i put it in that it didnt make sense, and that is because it was wrong, duh.i need to slow down and take mytime. this post can be deleted now
Cioffie
May 19, 2013 10:24 PM
azr3al
Dec 30, 2011 12:37 PM
inventorA6
Apr 15, 2009 06:46 AM
less_of_me
May 2, 2007 03:29 AM
