2.7TT S-line Trouble
Old Sep 28, 2011 | 02:00 PM
Schmity764's Avatar
Default 2.7TT S-line Trouble
I have an issue with my turbos...I satart my car and let it warm up everytime before i drive it. When i begin to drive the turbos spool up correctly but after driving for about 5 minutes the lag like crazy and dont produce good boost and my car is super slow! When i restart my engine it just repeats!!! I have no idea what would cause this so please let me know what i can do to diagnose this asap
Thanks,
Schmity764
Old Sep 28, 2011 | 06:26 PM
bob martin's Avatar
How do you know its your turbos? What tests have you done? What results have you acquired?
Bob
Old Sep 29, 2011 | 12:41 AM
Schmity764's Avatar
I assumed...what other components could it be? What tests can i run?
Old Sep 30, 2011 | 09:04 PM
oldmots's Avatar
Maybe the bypasses are opening at low boost.
Old Oct 1, 2011 | 12:29 AM
hxgaser's Avatar
Typical boost leak symptom I think... Visually check all the hoses. Sure way to tell is to run a pressure test. Google is your best friend.
Old Oct 1, 2011 | 06:00 PM
Schmity764's Avatar
Thing is is it runs fine when i begin to drive I step on the gas from stopped and it goes great...then it switches to 2nd gear and for like have a second its fine then they begin to lag like crazy but its like instant!
Old Oct 1, 2011 | 06:52 PM
hxgaser's Avatar
You probably have a loose hose or a crack in one that is opening up.
Old Oct 2, 2011 | 04:01 AM
Schmity764's Avatar
Throttle body boot! I checked it twice and the third time i found a crack going up the center split thanks for the help and the part is on the way
nck7757
B7 Models
Sep 15, 2013 07:12 AM
Rdshepard80
Aug 20, 2013 05:20 AM
Rdshepard80
Aug 20, 2013 05:04 AM
buyaudi
Jan 7, 2013 11:43 PM
cefurod
Apr 2, 2009 08:45 PM
