2000 a6 calipers
Old May 20, 2009 | 11:24 AM
dyamxA6's Avatar
Default 2000 a6 calipers
IM TRYING TO REMOVE MY FRONT CALIPERS. I WAS TOLD THAT THERE ARE TWO HEX SCREWS TO BE REMOVED AND THE CALIPER WILL BECOME LOOSE...
I REMOVED THE TRIM CAPS TO ACCESS THE SCREWS BUT THERE WERE NONE. JUST A HOLLOW CYLINDER. NO SCREWS WHAT SO EVER...ARE THERE ANY PINS???
ANYONE HAVE ANY INPUT??
CAR IS 2.7t
Old May 20, 2009 | 12:26 PM
TwinTurboC5's Avatar
Default Caliper Bolts
Hi DyamxA6,
The bolts (not screws) that you are refering to are located on the inside (backside) of the caliper. If you look on the backside of the caliper...by putting your head in the fender opening or just using a mirror, you should be able to see them. The bolts on the front caliper should be Hex Head bolts (size 5/16).
nothsa
Apr 30, 2012 08:21 AM
plinko89
Mar 8, 2012 11:56 PM
plinko89
Feb 27, 2012 07:30 AM
ibe3pac
Dec 12, 2006 05:08 AM
