2000 A6 Quattro 4.2 V8 - Check Engine Light ERRORS
Hello All,
I'm getting the following Error. P1128 - Upstream Heated O2 Sensors Swapped P1130 - Lack of H02S Switch - Adaptive Fuel at Limit P1141 - Fuel Restriciton Indicator Circuit Malfunction P1 - is a Manufacture Type Error Does anynone know a quick resolution to these Errors? Also, what does it actually mean? Thanks. Ricardo |
RE: 2000 A6 Quattro 4.2 V8 - Check Engine Light ERRORS
P1128 long term fuel trim system too lean bank 2
P1130 long term fuel trim system too lean bank 2 P1141 load calculation implausible value "wiring/MAF sensor" it could be an air leak round the MAF sensor pipe |
Avant80@2.6
I don't know much about cars, or machanical fixes. Do you know to fix this problems in the car? Or perhaps estimate the amount of money $ it will cost to fix each error? Thanks, Ricardo |
P1141 is Load Calculation Cross Check Range/Performance
i drive 4.2 a6 and i get the same code today ill try to call audi ask them |
