2000 A6 Quattro 4.2 V8 - Check Engine Light ERRORS
Old Apr 14, 2006 | 02:01 PM
rico6xrico's Avatar
Default 2000 A6 Quattro 4.2 V8 - Check Engine Light ERRORS
Hello All,
I'm getting the following Error.
P1128 - Upstream Heated O2 Sensors Swapped
P1130 - Lack of H02S Switch - Adaptive Fuel at Limit
P1141 - Fuel Restriciton Indicator Circuit Malfunction
P1 - is a Manufacture Type Error
Does anynone know a quick resolution to these Errors? Also, what does it actually mean?
Thanks.
Ricardo
Old Apr 14, 2006 | 02:47 PM
techbod's Avatar
Default RE: 2000 A6 Quattro 4.2 V8 - Check Engine Light ERRORS
P1128 long term fuel trim system too lean bank 2
P1130 long term fuel trim system too lean bank 2
P1141 load calculation implausible value "wiring/MAF sensor" it could be an air leak round the MAF sensor pipe
Old Apr 14, 2006 | 03:19 PM
rico6xrico's Avatar
Avant80@2.6
I don't know much about cars, or machanical fixes. Do you know to fix this problems in the car? Or perhaps estimate the amount of money $ it will cost to fix each error?
Thanks,
Ricardo
Old May 22, 2006 | 01:50 PM
maciunast's Avatar
P1141 is Load Calculation Cross Check Range/Performance
i drive 4.2 a6 and i get the same code
today ill try to call audi ask them
petemx5
Oct 6, 2011 08:27 AM
mabtheone
Apr 11, 2011 08:25 AM
mjhcc
Mar 11, 2011 08:04 AM
s4maryland
Dec 2, 2008 07:35 PM
dph138
Mar 9, 2006 03:55 PM
