2000 audi a6 4.2 quattro
Old Jan 4, 2012 | 04:56 AM
duck4u1987's Avatar
Default 2000 audi a6 4.2 quattro
I Have had so many probs with my car but i love it. I have a p1545 coad it is the throttle POS Do i need to replace the throttle body? i can turn the car on and hit the gas it does nothing wont even rev. but it will if i start the car a few times. this is weird because i just got my car outta the shop and it just started doing this. I havnt drivin my car in so long because its one thing after another with it. so my question is should i replace it or is there something els i should do. i was told i cant just change the sensor i have to change the whole throttle body. is this true??
Old Jan 4, 2012 | 05:16 AM
bigdadi's Avatar
Try cleaning the throttle body. Then recalibrate the throttle body position by disconnecting the battery, and waiting as noted below.
Disconnect the battery only if you have the radio code. Anyways, disconnect for about 5 to 10 minutes. Reconnect and turn the key to on position without starting the car. Let it sit for a couple of minutes and it should be it.
Old Jan 4, 2012 | 09:39 AM
budhani786's Avatar
^^^THIS
also dont worry about the radio code. ive disconnected my battery atleast once every 2 months and never once have i had to have the radio code.
Old Jan 5, 2012 | 02:44 AM
duck4u1987's Avatar
Thank you i will try this tomorrow and post back with the out come. I have a non stoke radio so its no big deal for the coad
Old Jan 5, 2012 | 08:25 PM
duck4u1987's Avatar
Ok so i tried this and it didnt work, i also put the wrong coad its p1568
Old Jan 6, 2012 | 11:49 AM
bigdadi's Avatar
P1568 - Audi
Type ... Powertrain - Manufacturer Controlled DTC - Manufacturer Controlled
Description ... Throttle control unit - mechanical fault
Cause ... Throttle valve tight/sticking
Notes ... Throttle control unit incorporates the following components: TP sensor, CTP switch (if fitted), ISC actuator/position sensor or throttle motor/position sensor.
Try also: http://www.obd-codes.com/p1568
Old Jan 6, 2012 | 07:26 PM
duck4u1987's Avatar
Im lost what should i do? replace what??
Old Jan 6, 2012 | 08:28 PM
budhani786's Avatar
from my 5 mins with google ive read that this code is caused by the throttle body. replace it.
a person took his out and found a plastic stuck to his which was causing the error. you should probably do the same take out and clean it.
read this carefully
Where are these?
good luck
Old Jan 6, 2012 | 09:03 PM
duck4u1987's Avatar
took throttle body out and cleaned the crap outta it. still same prob. esp light traction control light and check engin light still on, wont rev past 1 1/2 rpms throttle body wasnt getting stuck or anything.
Old Jan 6, 2012 | 11:05 PM
budhani786's Avatar
try and post this on audizine and audiworld. more places you post more answers youll get.
