2000 Audi A6 - Need Help with Some Cut Electrical Wires
3 Attachment(s)
Bought a used 2000 Audi A6 Avant Quattro with 2.8 engine recently and have had some major issues. There was apparently some front end damage that was not correctly repaired. I was thinking about selling the car for parts, but ended up getting a refund and being able to keep the car. So, now I basically have a free 2000 Audi A6 Avant quattro with 130k and trying to figure out if it is worth keeping and fixing it up. Anyways, I've fixed some of the cobbed body/fender damage, but noticed some cut wires and un-connected electrical fittings and was hoping for some help in identifying them. Car seems to run fine, no CEL, and Vag-Com scan is clean, so I am hoping they are for convenience items. I have the Bentely Service Manual, but really didn't find it helpful in identifying the wires. I've attached some pictures and thank you all in advance for any help you can offer.
First set of cut wires I found was inside the front passenger side fender, near the front bumper mount screws on the passenger side. There is a package wire cluster that has two wire pairs. One pair is a yellow and brown wire; the other is two black wires. Maybe brake pad sensor and homelink receiver wires? Second issue is a cluster of wires, sensor connections under the plastic cover near the power steering fluid reservoir. There's one connector unconnected (white facing up in picture), another purple on top/green on bottom also unconnected, and a black one with what you may call an accordian elbow (two black wires exiting). Again hoping that these are non-essential wires, but want to know how to fix otherwise. |
1 Attachment(s)
First what motor do you have? I have a 2001 A6 4.2 and I have also have had a 2000 v6 passat and the connectors were almost the same in the same location. You are missing the two large oval connectors for the A/C cooling fans that should be mounted one in front and one in back of the radiator and condenser. The green connector is for the A/C clutch. There should be one for the hood latch sensor. one for a sensor that is mounted in front of the condenser that is for the out side air temp. one for the fan switch. I have attached a pic of what mine looks like
Thanks for the reply and photo. I do have one of the large oval ones loose from the carrier. It was not connected when I got the car, when connected the AC fan typically comes on even when the engine is cold. Not sure where the other large oval wires are or other missing wires. I was hoping I could do this myself, but my Bentley manual isn't very helpful, so I appreciate any help I can find on this forum. I will probably end up taking to a local indy audi mechanic to figure out how much it will cost to put this thing back together correctly and whether it is even worth fixing.
there is also a control module mounted in the bumper so if it is kicking on when its cold it is bad and i know they run around $200. if you are in the chicago area I could also give u a hand on fixing it. have you checked if your a/c compressor kicks on? i was just looking at a wiring dig for your motor and i think you will only have one connector. do you have one or two electric fans? Do you get your outside temp on your cluster?
Originally Posted by cmlltan
(Post 1285819)
