2001 A6 2.8 FWD C5 19" wheels 235 new front end and having trouble with alignment
Old Jan 31, 2012 | 02:05 PM
stephenmalone's Avatar
Exclamation 2001 A6 2.8 FWD C5 19" wheels 235 new front end and having trouble with alignment
So this past weekend I rebuilt the entire front end on my A6. All new control arms, tie rods, cv's etc. All done and ran great. I took in for alignment with a new set of 19's I just acquired and when they had it plugged in to the computer they had trouble aligning it. The guy said the rear trailing arm on the left side was adjusted as much as it could be adjusted and was still about a 1/2 or 1/4 inch out which causes the car to dogwalk (back end tracking to the right while going straight) He said the rear trailing arm is probably out of wack unnoticeably. I called audi this morning and they said it's because of the 19's and that there is no room left for adjustment on the trailing arm. But then how come the right side rear was fine ?? Is my trailing arm bent ? Should I try to install a new one ? Anyone with 19 or bigger wheels have trouble with this or alignment in general ?? Any input would be appreciated.
Also need to lower the car now. whats the most inexpensive way to lower about 3 inches in the front and rear ? The 19's with 235's on stock ride height went on perfect with no rubbing at all. just want to eliminate all that gap in the wheel well.
But the trailing arm thing is mindboggling. I need help!! blaufernugen.
Old Feb 20, 2012 | 01:10 AM
punisher9's Avatar
i have 19on on mine and it aligned well but i have 225 35 tires on it are yours 235 35 because I'm trying to see how big i can go tire wise with out having it rub 225 35 is to small. but car should align god i got mine done a few months ago
Old Feb 20, 2012 | 06:18 AM
RGT's Avatar
RGT
sorry can't help about the allignment issue, but I am curious about which front end kit you used? I have seen several options and they all seem to say they are an improved design over the originals with harder bushings...
Thanks, and good luck
ESH
May 5, 2012 12:11 PM
dchicanw
Oct 26, 2010 10:23 AM
morpheous
May 28, 2010 09:36 PM
rcs128
Nov 28, 2009 02:24 PM
one_eightT
Feb 13, 2009 01:16 PM
