2001 A6 2.8 Vacuum diagrams?
Old Apr 11, 2011 | 02:22 PM
OzzyLime's Avatar
Default 2001 A6 2.8 Vacuum diagrams?
I looked all over and i cannot find any vacuum hose diagrams for my 2001 A6 2.8. Anyone have these to share? Thanks
Old Apr 11, 2011 | 02:44 PM
OzzyLime's Avatar
Follow up. If anyone would take a picture of their vacuum setup that would work too. Thanks.
Old Apr 12, 2011 | 12:04 AM
hxgaser's Avatar
There is one under your hood too.
Old Apr 12, 2011 | 08:01 AM
OzzyLime's Avatar
I found mine too, thank you. The only vacuum line disconnected was the reservoir. What is the name of the hard plastic line below? * Mine snapped, will it make the motor run horrible?
Old Apr 12, 2011 | 11:57 AM
hxgaser's Avatar
That is your crank case breather hose. Yes it will make your car run rough. You can find it here.
Judging by the picture, I recommend that you pick up about 5 feet of 3/16" vacuum hose from local parts shop and replace all vacuum hoses. Just replace one at a time to track where it goes.
Old Apr 12, 2011 | 11:59 AM
hxgaser's Avatar
Oh, don't forget to reconnect the vacuum reservoir line to the front of the car. The original plastic gets really brittle. I had to replace mine just over the weekend when I was replacing the valve cover gaskets. It pretty much disintegrated.
Old Apr 12, 2011 | 12:15 PM
OzzyLime's Avatar
Thank you very much for the replies. Picked up silicone vacuum line and will replace them tonight. Any idea what sensor this is to the right of the crank pulley? It has a nipple connector.. maybe it needs a pigtail or something?
Old Apr 12, 2011 | 12:54 PM
chefro's Avatar
Oil temp sensor - it screws into the oil pump housing.
Old Jun 14, 2012 | 09:43 PM
chuck_eglin's Avatar
Default 2001 A6 2.8 Vacuum Reservoir Location?
Sorry for posting to this old thread but you all had excellent info that sheds light on our problem. My daughter's 2001 A6 2.8L AT with 148K miles has a hard plastic 3/16"? hose above the driver's side engine bank going towards the front of the engine that is not connected. We plugged it with a rubber cap but it appears to go to the vacuum reservoir seen in the first diagram of this thread and highlighted by hxgaser's post. Can you tell us where this vacuum reservoir is located in the engine compartment? We can't locate it but we assume it is somewhere close to the driver's side wheel well or close to it. We don't have the Bentley manual for it and hope to get one soon. Thanks in advance for any help. Sincerely, Chuck
Last edited by chuck_eglin; Jun 16, 2012 at 08:48 AM. Reason: Left off important information required by moderators
Old Jun 19, 2012 | 11:49 AM
hxgaser's Avatar
Take the driver side wheel off and remove the plastic wheel well cover. It looks like this.
