2001 A6 4.2 Fog Light
Old Nov 22, 2004 | 09:45 PM
dstadler's Avatar
Default 2001 A6 4.2 Fog Light
Hi,
I recently purchased a used 2001 A6 4.2 What a great ride!
One of the front fog lights needs to be replaced. If anyone can offer a detailed procedure for removal and replacement, I would really appreciate it.
Thanks in advance,
Dan
Old Nov 22, 2004 | 10:49 PM
Jestnomen's Avatar
6th Gear
Default RE: 2001 A6 4.2 Fog Light
well it should probably be similar to an A4. remove the trim around the fog light. There should be several screws holding the light in. Remove them and pull the light out. Remove the wire connector from the rear of the foglight housing. remove cover and swap bulbs.
Old Nov 25, 2004 | 10:21 PM
Ted's Avatar
Ted
Jestnomen is right, there is just a cuple screws holding it in, on the back side is a small peice of steal that has two holes that the fog light screws into, and if the light dose not want to go in, thats your problem, not hard.
o0hmikee
Feb 19, 2015 01:08 PM
tmani
Apr 4, 2009 01:51 PM
pologoped2
Feb 10, 2009 08:56 AM
mys4.org
Dec 11, 2008 01:25 AM
General Jackson
Jul 19, 2005 03:12 AM
