2001 A6 Interior Bulbs?
Hi All,
I'm trying to replace my interior bulbs with some LED bulbs from http://www.superbrightleds.combut the numbers on the bulbs don't seem to return many results when using their search function. I checked Sylvania.com and didn't have much luck there either. I think I managed to finda cross-reference part number for one of the bulbs (see below). Does anybody know any of thealternate part numbers for these bulbs?
K5618 (Cross-Referenced as Part # 4410)
37R
3860
Thanks in advance.
-Jon
37R
3860
Thanks in advance.
-Jon
Check out 42 Draft Designs for your LED's. I am replacing mine as we speak. Our interior uses wedge style lights in the doors, 39mm fuse style lights under the dash, under the driver and passenger seat, in the trunk, gloveboxand in the overhead light by the sunroof. The reading lights are a push and turn style. This is what I've been working on so far. I am not sure what bulbs are used by the license plate but thats coming soon.
Hope this helps!
OOOO
I know this maynot be the biggest help, but it has some of our interior lights
2003 AUDI A6 (With HID (high intensity discharge) headlamps)
Low beam headlamp
HID-D2S
High beam headlamp
H7
H7SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
H7ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H7XV XtraVision Halogen - The Brighter Light
H7CB Cool Blue Halogen - The Whiter Light
Parking light
3457ALL
3457AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
Front turn signal
3457ALL
Rear turn signal
7506
7506LL Long Life Upgrade: Up to twice the life of the standard lamp
Tail light
7528
7528LL Long Life Upgrade: Up to twice the life of the standard lamp
Stop light
7528
High mount stop light
70
Fog/Driving light
H3-55W
H3ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
License plate
6418
6418LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
7506
Front sidemarker
3457ALL
Rear sidemarker
7528
Glove box
6418
Map light
64111
Dome light
6411
Step/Courtesy light
2825
2825LL Long Life Upgrade: Up to twice the life of the standard lamp
64111
6418
Trunk/Cargo area
6418
Under hood light
6411
Daytime running light
2825
[/align]
__________________________________________________ __
The applications presented in this replacement guide have been compiled using the best information available from the vehicle manufacturers at the time of your search. This guide is intended for general information purposes only, not to be construed as any type of warrantee as to any particular application. For specific applications the vehicle owner's manual should be consulted.
Low beam headlamp
HID-D2S
High beam headlamp
H7
Parking light
3457ALL
Front turn signal
3457ALL
Rear turn signal
7506
Tail light
7528
Stop light
7528
70
Fog/Driving light
H3-55W
License plate
6418
Back up light
7506
Front sidemarker
3457ALL
Rear sidemarker
7528
Glove box
6418
Map light
64111
Dome light
6411
Step/Courtesy light
2825
64111
6418
Trunk/Cargo area
6418
Under hood light
6411
2825
[/align]
Thanks guys,
I'm only putting LEDs in the front and rear dome lights, the front and rearsmaller push button lights, and the lights in the sun-visors. I measured the bulbs, converted them to millimeters and matched them to the bulbs on superbrightleds.com. This should be fine for the festoon bulbs but there's a chance the push and turn ones which they call bayonet bulbswont fit ($5 for them so no biggie). I'll let you know how they fit/look when they arrive.
And I did see those bulbs listed on Sylvania.com but they didn't cross-reference on superbrightleds.com.
-Jon
-Jon
The LEDs came in the mail and they all fit fine
There is a small problem though: They all light up fine when I open one of the doors but if I manually turn them on (by hitting the roller-switch), they don't turn on. I can see a slight flicker of light from the smaller push-button lights (seems as though the LED bulbs aren't drawing or gettingenough power). I know LEDs consume less power but I don't understand why they would work fine when opening the door but not work at all when hitting the switch. It seems as though when you open a door (or unlock the doors), the lights are getting power from a different circuit than when you manually turn them on. Any ideaswhy this might be happening? Thanks.
.There is a small problem though: They all light up fine when I open one of the doors but if I manually turn them on (by hitting the roller-switch), they don't turn on. I can see a slight flicker of light from the smaller push-button lights (seems as though the LED bulbs aren't drawing or gettingenough power). I know LEDs consume less power but I don't understand why they would work fine when opening the door but not work at all when hitting the switch. It seems as though when you open a door (or unlock the doors), the lights are getting power from a different circuit than when you manually turn them on. Any ideaswhy this might be happening? Thanks.
Ha...If I can get em working right I'll get some pics up. Maybe the light-sockets are supplying too much power for the LEDs? I tried Googling this but didn't find anything. I hate electrical problems because they're always really strange and a royal PITA.
Still no luck getting the LEDs to function properly (turn on without having to open the door or remotely unlock the doors) so I figured I'd bump with some pics(in the 1st picture, you cansee the difference betweenthe yellowish factory lightsand the whiteLEDs). From these pictures, you can't really see how they light up the whole interior but IMO, it looks so much better...andbrighter. I took a short video too (which again,is fairly darker than it looks in person): http://www.youtube.com/watch?v=iAMj6e7N2DE.
Nice one............I'm trying to upgrade some of my bulbs on my A6 (07) and am being told that it will cause problems[&:]
The car is so technologically advanced blah blah blah.........wont draw enough current, get bulb out messages etc.
I was hoping to add leds to the sidelights, reversing lights and possibly the stop/ tail too.
Anyone???
Help appreciated
Jim
Anyone???
Help appreciated
Jim
Yea, I know the car will probablythink your bulb is out so it will blink fast and tell you its out. I believe in most (if not all) cases,you can install low-resistance resistors to get around this but it may be a different case with Audis. I'm staying away from the exterior lighting for now (especiallysince I can't even get the interior drop-in LEDs to work properly
