2001 A6 Tie Rod ends lined with rubber??
Old Sep 26, 2010 | 10:22 PM
diablo10's Avatar
Default 2001 A6 Tie Rod ends lined with rubber??
I took my 4.2L A6 to get a wheel alignment, they could not free up the adjusters. The mechanic said that he could not heat the inner or outer tie rod end because he believes they are lined with rubber and they will burn off , so I need a new set of inners and outers. Has anyone heard of rubber lined tie rods? Thanks
Old Sep 26, 2010 | 11:24 PM
TwinTurboC5's Avatar
Default Control Arms
Your tie rod ends all have rubber inner bushings/dampeners in them, and like the Tech told you, if he heated them with a torch there will likely be damage to these because of the intense heat. Before buying new ones, to have your alignment performed...I would recommend spraying the adjustment nuts and threads liberally with penetrating fluid. All of these fasteners will corrode over time, escpecially if you live in a northern climate where salt is used to deice roads in the winter.
PB Blaster is a good penetrant that I use and keep in the garage for these jobs. Royal Purple also makes one that is a synthetic and very effective. You can buy them both in an aerosol and over the counter at any auto parts store.
I'd try this first....$5 bucks for this vs hundreds with parts and labor for new inner and outer tie rod ends that you may not need.
Old Sep 27, 2010 | 11:45 PM
diablo10's Avatar
Thanks for your input, Do both the front and rear tie rod ends have the rubber or just the rears?
Old Sep 28, 2010 | 08:43 AM
bob martin's Avatar
Both do.
s4tech
Jun 23, 2008 04:08 PM
jaydubyagee
Apr 15, 2006 10:03 PM
trey
Oct 3, 2005 11:50 AM
BFlan2001
Sep 28, 2005 12:56 PM
BFlan2001
Apr 5, 2005 11:00 AM
