2001 A6 will not crank
Old Jun 26, 2008 | 07:00 PM
styliaras's Avatar
Default 2001 A6 will not crank
Hello everyone,
I am hoping that someone has seen this issue I am having.
It all started when my wife told me that the battery light came up. So I checked everything and sure enough there was a problem. I changed the battery (it needed one) and the alternator. When I tried to start the car, it did not crack at all. I do not even hear the solenoid kicking in. At this time because I am fed up, I changed the starter also. But it still does not crack at all.
So this is what I have checked so far:
1) Immobilazor recognizes the keys
2) I have always 12V to the starter
3) When I try to start, the signal wire has 12V
4) There is ground to the starter.
5) I have checked the relay under the dash
6) Checked the starter outside from the trans and it works when I apply voltage.
Am I missing something? Am I supposed to do something with the computer e.g. erase any codes?
Help! Don't want to take it to dealer.
Thank you in advance
Demetri
2001 A6 2.8 Quattro
Old Jun 27, 2008 | 10:13 AM
hxgaser's Avatar
Default RE: 2001 A6 will not crank
I had the same problem. Ignition switch was the blame. The following is a link to a DIY that I did.
https://www.audiforums.com/m_736667/tm.htm
Hope it solves it.
flinter801
May 22, 2014 12:11 AM
turbo2475
Mar 19, 2014 11:05 AM
Grumpy10
Apr 21, 2012 09:25 AM
mckeenr
Nov 25, 2009 11:16 PM
Iowa A6
Oct 29, 2007 11:12 PM
