2001 Audi A6 4.2L Transmission Problems, Limp Mode Resale Value
Old Mar 28, 2014 | 06:59 PM
journe's Avatar
Default audi A6 2001 v8 4.27
i have the same exact car with the same problem wont drive in reverse wonder if i bought yours lol
Old Apr 1, 2014 | 05:12 AM
pluto72's Avatar
Default Audi A6 1995 2,8L
Hi all does any buddy know how to service a Audi 2.8 L automatic.I replace the oil and filter but i think i have made something wrong my car goes into gear but does not move .
Old Apr 14, 2014 | 01:02 AM
cyangant's Avatar
Default pluto72
Are you sure you didn't drain the ATF? That drain plug is very close to the oil plug on the bottom of the cars. If this happened you have an empty tranny and overfull engine, assuming you put oil back in since you said you started the car.
Old Apr 14, 2014 | 09:19 AM
pluto72's Avatar
Default Audi A6 2.8 L 1995
I am not sure where the plug is.A normal car or pickup is right on the bottom.As u know the audi has the same,exept it has a plug on the side but not right on the bottom. i would say about 70 mm from the bottem of the sump .I hope PLease help not sure what to do .That car is (was) in very good condition .In south Africa not a lot of people know how to work on this caR
tHANKS
Old Apr 14, 2014 | 04:47 PM
martt1ski's Avatar
Originally Posted by jlustig
Hello, I have a 2001 Audi A6 4.2. The tranmission has started giving me problems. Currently the car is in limp mode and can only be driven in a certain gear. Its a transmission safe mode. The car has been tested and there are internal problems in the transmission that need to be fixed.
How much do you think this repair will cost?
I would need the transmission rebuilt. I received an estimate for a new transmission at $5000. Way too much not worth it.
If its too pricy I would probably end up having to sell the car the way it is with transmission needing repair. How much money do you think I get for a car in that condition.
First - get vehicle on VAG tool - you may have solenoid problems, etc.
Second- (and to address the reverse gear issue mentioned in thread) the -24 and other variants of this ZF trans have reverse drum issues - I had mine rebuilt due to reverse drum failure for ~$3900 w/an 18 mo warranty by an independent shop. In my case, the car was worth keeping w/only 75K miles.
Old Oct 17, 2014 | 02:25 PM
Joelkj's Avatar
Default 98 A6 Quattro...auto trans problems
Thanks for all the info. My AT is steadily getting worse...no reverse problems. Seems to run only in 2nd or 3rd once it's warm....I love the car, only 98K miles.
madgunz
Apr 21, 2011 12:36 PM
jpcallmotor
Jul 9, 2010 01:41 PM
badge424
Dec 20, 2007 03:13 PM
jeromehawaiii
Aug 1, 2007 08:41 PM
