2001 Audi A6 Quattro 2.8L Automatic 100k miles Brake Light Blinking and ABS solid
The Brake Light was blinking and ABS was solid so I changed my front brake pads rotors and sensors. I noticed the front driver side sensor was cut so I had to rewire the sensor by hand.
After replacing these my brake light is blinking and ABS is solid. When I first start the car it beeps 3 times.
When I try to run a VAG-COM on the ABS and Brakes I get a error. Although I do get this message
Address 02: Auto Trans
Controller: 4B0 927 156 G
Component: AG5 01V 2.8l5V USA 8509
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Could a faulty brake light switch cause both the ABS and Brake light to appear?
Any other suggestions on this?
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
umoms
Jan 16, 2009 06:20 PM
jmorris1@vt.edu
Mar 31, 2007 01:04 AM
