2002 2.7 tiptronic gear searching
Old Mar 30, 2011 | 04:25 PM
Aikijoe's Avatar
Default 2002 2.7 tiptronic gear searching
When cruising at low rpm's in a high gear with light throttle pressure engine rpm's will raise and fall consistently. Will also do it at times when it should downshift. Mostly happens in 5th gear sometimes forth gear. Changed fluid and filter last year. Any help would be appreciated.
Old Mar 30, 2011 | 04:43 PM
bob martin's Avatar
Locking torque converter doing its job. Try driving faster.
Old Mar 30, 2011 | 11:56 PM
Aikijoe's Avatar
yeah that makes it go away but it never did this before just started maybe a week or two ago. Maybe a transmission speed sensor or something? I had a diesel truck that did the same thing, It had a bad engine speed sensor.
Old Mar 31, 2011 | 04:51 PM
bob martin's Avatar
Could be the start of your torque converter going bad. Have you tried Sport mode versus regular mode? That should change the lock/unlock characteristics somewhat.
Bob
Old Mar 31, 2011 | 06:00 PM
Aikijoe's Avatar
Bob
Yeah, in sport mode it does it less often, the rpms have to be low for it to happen
StrongTyer
Jun 2, 2013 05:12 PM
Ky allroad
Feb 25, 2009 06:15 PM
XxGRYPHONxX
Jan 28, 2008 09:14 PM
shelbyturbo
Dec 9, 2007 04:08 PM
BILL928S4
Dec 28, 2004 01:41 AM
