2002 A6 2.7 quattro crankshaft position sensor how to replace
Ok guys, so I am trying to replace the cps which I have located driver side engine block by the axle.
However, I can't see where the cable is going. I can't see where the other end connects. so the one that goes in the engine has a 10 bolt. the other end is an electronic connection. (a plug with 3 teeth). Sorry for my language but I am not familiar with the terms in English. How do I replace it???? Pleaseeeee Heeeeelp! |
Sounds like you found the CPS & single 10mm bolt. There should be a black wire mounted to it & that wire snakes upward on the back side of the block & over to the driverside firewall. There are several connectors mounted on a black plastic holder on the DS firewall. One of them is the CPS connector.
http://i46.tinypic.com/11ca3p0.jpg
http://i47.tinypic.com/2dqj0xt.jpg http://i45.tinypic.com/xuayq.jpg 17. G28 Looks to be behind the Expansion/Coolant Tank. Judging from the diagram, it should be the connector on the right (match with the new part if not sure). |
