2002 A6 Fuel and temp gauges not working
Old Feb 15, 2005 | 09:25 PM
chris2004's Avatar
Default 2002 A6 Fuel and temp gauges not working
Just had someone call with his A6 .
he said his window washers weren't working so he put 12 volts to the washer motor with the wires still connected.
Now the fuel gauge is not working or the water temp and the lights on the dash are flickering..
I put the vag com on the car but i am not sure of the fault here are the fault here are the fault codes. (The car was a damaged repaiarable over a year ago)
VAG-COM Version: Release 409.1-US
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56,76
Address 01: Engine
Controller: 038 906 019 CF
Component: 1,9l R4 EDC G000SG 1414
Coding: 00002
Shop #: WSC 02325
WAUZZZ4B12N024890 AUZ7Z0A1902032
3 Faults Found:
18027 - Glow Plug Relay (J52): Open or Short to Ground
P1619 - 35-10 - - - Intermittent
17932 - Fuel Pump Relay (J17): Open or Short to Ground
P1524 - 35-10 - - - Intermittent
18080 - Coolant Fan Control 1: Open or Short to Ground
P1672 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes
Controller: 4B0 614 517 G
Component: ABS/ESP front 1728
Coding: 06255
Shop #: WSC 02325
2 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
00526 - Brake Light Switch-F
36-10 - Open Circuit - Intermittent
Address 08: Auto HVAC
Controller: 4B0 820 043 AC
Component: A6-Klimavollautomat 0104
Coding: 00104
Shop #: WSC 02325
No fault code found.
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 4B0 920 981 J
Component: KOMBI+WEGFAHRS. VDO D07
Coding: 00440
Shop #: WSC 02325
2 Faults Found:
00771 - Fuel Level Sensor (G)
30-00 - Open or Short to B+
00668 - Supply Voltage Terminal 30
53-10 - Supply Voltage Too Low - Intermittent
Address 35: Centr. Locks
Controller: 4B0 962 258 K
Component: Zentralverrieg.,DWA D35
Coding: 06859
Shop #: WSC 02325
6 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01559 - Drivers Door
60-00 - Won't Safe
01561 - Left Rear Door
60-00 - Won't Safe
01562 - Right Rear Door
60-00 - Won't Safe
01134 - Alarm Horn (H12)
76-10 - Terminal 30 missing - Intermittent
Address 45: Inter. Monitor
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 02325
Address 55: Xenon Range
Controller: 4Z7 907 357
Component: dynamische LWR D06
Coding: 00040
Shop #: WSC 02325
2 Faults Found:
01533 - Terminal 56 (High Beams)
Address 56: Radio
Controller: 4B0 035 195 H
Component: symphony II NP2 0005
Coding: 00001
Shop #: WSC 02325
Address 76: Park Assist
Controller: 8Z0 919 283
Component: Parkingsyst. A6 RDW D08
Coding: 00106
Shop #: WSC 02325
End --------------------------------------------------------------------------------------------------
pauly8888
Nov 7, 2013 05:33 AM
Backyrd
Mar 19, 2013 12:44 AM
twoeightquattro
Jan 10, 2012 03:39 PM
Tzar177
Jun 28, 2011 11:22 AM
dlt21
Jun 17, 2006 10:13 PM
