2003 A6 V6 - fault code P1120/17528 - B2S1 oxygen sensor replace
Old Jan 8, 2013 | 01:07 PM
crisTSM's Avatar
Default 2003 A6 V6 - fault code P1120/17528 - B2S1 oxygen sensor replace
2003 A6 V6 automatic (no turbo, no quattro)
71,700 miles
Check engine light on.
Car starts and runs o.k.
Checking with ross-tech cable and software shows:
17528 - oxygen (Lambda) sensor heating; B2 S1
P1120-004 - open circuit - intermittent.
To replace the part, I used following spare parts and tools:
2003 A6 V6 - fault code P1120/17528 - B2S1 oxygen sensor replace-01-part-tools.jpg
Bosch Oxygen sensor part #17113 (with connector), purchased from Auto Zone (online) for $106.99
Oxygen sensor wrench - item "powerbuilt 648691 oxygen sensor offset puller", purchased from amazon for $7.61.
I used a short (5" - 6" long) ratchet wrench to have a bigger rotation angle in the space available.
All other tools are standard (metric).
I open/close the coolant tank cap (with cold engine) to release any remaining presure from the system.
Move aside the coolant tank by disassembling one hose (red arrow) and 2 screws (green arrows):
2003 A6 V6 - fault code P1120/17528 - B2S1 oxygen sensor replace-02-engine-bay.jpg
2003 A6 V6 - fault code P1120/17528 - B2S1 oxygen sensor replace-03-working-area.jpg
2003 A6 V6 - fault code P1120/17528 - B2S1 oxygen sensor replace-04-coolant-tank.jpg
Disconnect and move aside ignition coils connector and 2 camshaft position sensor connectors:
2003 A6 V6 - fault code P1120/17528 - B2S1 oxygen sensor replace-05-coil-connect.jpg
to be continued (I can upload only 5 pics at a time).
Old Jan 8, 2013 | 01:29 PM
crisTSM's Avatar
Default 2003 A6 V6 - fault code P1120/17528 B2S1 oxygen sensor replace (part 2)
2003 A6 V6 (no tutbo, no quattro) continuation:
Remove the cover of the oxygen sensor connector.
I post the photo to see the "locking"; lift the cover aprox. 3/8", incline it to the front of the car and lift up. I had to bend it to figure out this .
2003 A6 V6 - fault code P1120/17528 - B2S1 oxygen sensor replace-06-el-connect-cover.jpg
Disconnect the sensor connector:
2003 A6 V6 - fault code P1120/17528 - B2S1 oxygen sensor replace-07-el-connect.jpg
Observe the routing of the cable to be able to reproduce it and avoid future rubbing/burning of the cable.
The B2 S1 oxygen sensor is located, between the body and the flange of the catalytic convertor:
2003 A6 V6 - fault code P1120/17528 - B2S1 oxygen sensor replace-08-location-1.jpg
2003 A6 V6 - fault code P1120/17528 - B2S1 oxygen sensor replace-09-location-2.jpg
2003 A6 V6 - fault code P1120/17528 - B2S1 oxygen sensor replace-10-tools-place.jpg
Observe all the standard safety rules, you know what I am talking about - battery, hot/corrosive/irritant liquids, protection eye glasses and gloves, heavy objects, and so on...
Happy DIY !
saved4use
Aug 3, 2008 12:01 PM
inkhaton
Dec 26, 2007 01:00 PM
quattrolove
Nov 17, 2007 12:41 AM
to3o
Oct 4, 2007 09:19 PM
