2003 Audi A6 interior lights doesn't come on
I have 2003 Audi A6 3.0 , the interior lights doesn't come on at all , then the door open or closed. I cheked fuses and it's good, only red lights on a side of a door works and the foot lights works when you open a door. Somebody said what sometimes might be the short inside the seat? Does any body have any ideas how to fix this problem???
is there like a "master switch" (if you wanna call it that) that mayb accidently was hit into the off position. I no in my 99 A6 i have a switch near my Sun Roof control that lets me shut all the interior lights.
I contact with separate wire from fuses to the lights by sun roof and then lights came on, but I still can't find where might be a short along the cables. Anybody had this problem ?
I'm having the same problem with my 1997 Avant. A short ishighly unlikely if the problem is with all doors and the switches are OK. I think my problem is in the interior light delay module, but don't know for sure yet!
Its either a door latch malfunctioning or there is a TSB for a wire shorting out behind the driver's side seat to ground. Take it to the dealer and have them check those wires, you would have to remove the back part of the seat on the driver's side to see the wires.
ruslikua
Apr 10, 2011 04:46 AM
AudiAficionado
Nov 15, 2010 03:02 PM
