2006 Audi A6 Navigation Display Out
Old Dec 13, 2009 | 04:46 AM
neneago's Avatar
Default 2006 Audi A6 Navigation Display Out
The navigation/Radio display works fine in hot weather. Now that its cold outside, the display does not come on. It will come on after the car has been running for a while. The dealer wants $1100 to replace a circuit board they said is located by the cup holders. They said that I spilled coffee on the circuit board. ????? I'm thinking its a cold solder problem. Where should I look??
Old Dec 13, 2009 | 07:36 AM
Kevin's Avatar
Take a look at the TSB library that I set up with Dr. Cold. I have attached a link to the TSB that is the closest to the problem that I think you are experiencing. But there are several others dealing with MMI issues below 40 F.
http://www.uberlame.com/a6_tsb/MMI%2...%20degrees.pdf
Old Dec 15, 2009 | 02:31 AM
neneago's Avatar
What circuit board is located by the cup holder that the dealer talking about?
Old Dec 17, 2009 | 12:47 AM
JPJ2007's Avatar
Member
mines out but its just a bunch of vertical lines... never worked. dealer is suppose to replace it friday. we'll see
Old Jan 18, 2010 | 03:50 AM
neneago's Avatar
Im shocked that Im the only one with this problem.
Old Jan 18, 2010 | 07:08 AM
Kevin's Avatar
You are not the only one with this problem. It is a common problem and that is why Audi issued a TSB (Technical Service Bulletin). Did you read it?
Old Jan 19, 2010 | 02:51 PM
neneago's Avatar
Kevin...Is there somewhere that shows how I can replace the faulty part?
blindmonkey
Jul 11, 2012 11:33 AM
aa2by2
Sep 23, 2010 10:05 AM
robsmith
Aug 5, 2010 01:54 AM
jayton
Jun 6, 2007 11:51 PM
tomreed1234
Nov 28, 2005 11:35 PM
