4.2 Overheating, almost
Old Dec 10, 2008 | 08:02 AM
katcoota's Avatar
Default 4.2 Overheating, almost
Quick bit of background. Recently (in the last 15k miles) changed the waterpump and T-stat.
This week, my car temp has been going up more than normal. Normal is at midway. Now it goes to the next notch and sometimes a bit more. I have so far not had any beeps from the display to say engine overheating, but I'm concerned non-the-less.
Coolant level is ok. I have three fans in the engine bay. The motor driven clutch fan seems to be spinning happily all the time. AC fan starts when I start the AC on, as expected. I can't tell when and if the third fan is supposed to start. This is the V8 and it definetly has 3 fans.
Starting the AC on helps reduce the temp a little, which I would expect, but still not down to half way. Driving on the highway keeps the temp close to mid point, but still higher than normal.
Searched what I could, but without a clear answer. For starters, when is the third fan supposed to come on? What's the easiest way to check that it is working as there isn't a lot of space there.
I'm currently suspecting this 'third fan', a relay or a fuse. I'm hoping it is something simple.
Sorry for the long post, but I thought I would give as much info as I could.
Old Dec 10, 2008 | 08:54 AM
CoBra03TerminAtoR's Avatar
go with the rs6 wheels!! the rs4's in my opinion go good with the a4 but not with the a6 idk.. love my rs6 reps though
Old Dec 10, 2008 | 08:56 AM
ik that with your t-stat replacement you used new fluid.. but have you tried an actualy coolant system flush?
Old Dec 10, 2008 | 09:43 AM
katcoota's Avatar
The waterpump and t-stat were done in the summer, along with a couple of welds done to the radiator. Althought the system wasn't completly flushed, I can't imagine how much would be left after doing those three jobs. I had no problems doing a 6 hr drive at 110 mph in the summer at 113 degrees F. So I would be surprised if the fluid was going to be the issue.
There was a funny incident trying to get G-12 fluid for this. They ran out at the dealer. Not just the Audi dealer, the VW dealer, the Seat dealer and the Skoda dealer. Can you image a county with 25 million people running out of G-12!!! I couldn't believe it. Not only that, they couldn't give a date when it would be in. I had to use an alternative pink one (Toyota) recommended by an independent Audi tech as well as the Audi service desk.
I did think about the possibility of gelling because of the two mixtures, but again, I think it is not likely.
Old Mar 8, 2009 | 11:25 AM
katcoota's Avatar
Well, it turned out that the t-stat was getting stuck closed. It finally got stuck closed and it cost a fortune to have a 20 t-stat changed. It's basically almost like doing the timing belt job again. Clever design. I wonder who came up with it
BesI
Aug 4, 2011 12:18 AM
audi90quattro
Dec 18, 2008 12:18 PM
Sherman Banks
Aug 9, 2008 02:07 PM
Teutonic2.7T
Jul 3, 2008 11:50 AM
pete47
Apr 10, 2007 07:44 PM
