'99 A6 2.8L timingbelt/water pump
Old Aug 29, 2006 | 03:52 AM
a6speed's Avatar
Default '99 A6 2.8L timingbelt/water pump
I am planning to replace the timing belt on my 99 A6 2.8L, plus idler, roller, tensioner and water pump. I have two options for water pump: the OEM water pump by Geba which comes with a plastic impellar and the one by Graf that has a meral impellar, so I was wondering if one is better than the other. I'm getting two special tools: the crank holder and cam holder. Beyond that, I'd be grateful for any extra insight. Thanx
Old Aug 29, 2006 | 11:51 AM
Scotts's Avatar
Default RE: '99 A6 2.8L timingbelt/water pump
I did mine a while back and bought a kit and rented the tools from here:
http://www.blauparts.com/Audi_Parts_....htm#partsdept
everything went smoothly.
Old Aug 29, 2006 | 03:29 PM
a6speed's Avatar
Thanks, that is a great link... They suggest that the metal impellar water pump is better than the OEM with plastic. Does anyone know if I should also replace the thermostat and cam and crank seals, and is it a big deal to do?
Old Aug 29, 2006 | 03:43 PM
SloRide's Avatar
I used the TB kit from ECS tunning and it came with the Graf pump. so far so good, but don't forget to change the thermostat while you are at it too. I did a lot of research before I did the TB job and most talked about pulling the front end of the car off! Forget that. There is enough room between the motor and the radiator to jam in a soccer ball. Plenty of room on my 96 without having to go thru all that mess. The cam holding and crank holding tools are a must. A good set of socket driven metric allen wrench's helps.
Old Aug 29, 2006 | 06:36 PM
a6speed's Avatar
Well, the 95-97's are easier to work on, even though I am pretty impressed how Audi makes things accesible, lfor example, replacing spark plugs is a breathe, where on my 72 Buick, which has three times the room under the hood, the whole right bank is a wrestling match, and I have to remove the right wheel to get to spark plug #8. So I like my Audi.
Old Aug 31, 2006 | 12:40 AM
madbaird's Avatar
Replace your thermostat when doing the job. Just did by 2000 Avant and found out that if I had to replace it further down the road, I would basicly have to take everything off again.
clowninmd
S4
May 30, 2013 10:47 PM
MetalMan
Jul 19, 2012 09:15 PM
noob
Feb 21, 2010 12:57 PM
AUDIFIELD
Oct 28, 2009 03:20 PM
mctavish11
Oct 5, 2008 10:30 PM
