A6 2.7t won't run
Old Oct 7, 2014 | 08:22 PM
jmiller90's Avatar
Default A6 2.7t won't run
I'll start with the basic info:
2000 A6 2.7t Quattro, 212,000 miles
timing belt done maybe 25,000 miles ago
I do have compression, gas and spark.
Changed plugs, air filter and ignition control modules on air box due to a random multiple misfire code, as well as installing a used low mile master cylinder. After i got it back together it cranks but WILL NOT run.
Ran a Throttle Body Alignment, picked up another battery (mine was shot). Just today i ran an output test on the Maximus 2.0 tablet from silver eagle and when it cycled through the injectors on bank 1 i heard all 3 click, as if they had signals i assume? But i did not hear a response from the bank 2 injectors.
Almost done
Also, when i ran the throttle valve sensor measurements, G186 sensor 1 was around 14% and G188 sensor 2 was up at 86%. Are they supposed to match?
My audi has been down for 3 months and i'm kind of sick of driving my dads '95 SHO.
Any ideas anybody?
Old Oct 7, 2014 | 08:23 PM
jmiller90's Avatar
Default Almost forgot
Also, my EPC light is on, if that means anything.
