A6 2002 2.7t Rotors Need HELP!
Old May 3, 2006 | 12:50 AM
gajen0981's Avatar
Default A6 2002 2.7t Rotors Need HELP!
Hello To All Audi Fans,
I have A6 2002 2.7t and I need to replace the Front and Rear rotors. I have Audi part no for Front and I am looking for the specs on OD (Overall Diameter)
Is this true for the Front Rotors:
321 x 30 mm - Not Sure
Audi Part No: 8E0615301AD
Rear Rotors:
255 x 10 mm - Not Sure
I am getting EBC rotors for the rear (Drilled Slotted - Dimple Version)
I am looking to buy the front rotors. I bought one from Autopartswarehouse.com they are cheat bastards they dont have ware house they are agencies networking small time companies. DONT buy anything from there. They are based on NJ small time basement based company. I had bad experience with them.
If you you guys know the specs on Front Rotors and where can I buy them. I live in Boston, MA and if you guys know anything based on Boston that's even fantastic.
I appreciate your help.
Thanks,
Gajen
Old May 5, 2006 | 11:09 AM
gajen0981's Avatar
Default RE: A6 2002 2.7t Rotors Need HELP!
Hey Guys,
I got the rotors for my car.
For You Information:
For 2002 A6 2.7t (C5)
Front Rotors Dimensions: 321 x 30 mm (OD = Overall Diameter)
Rear Rotors Dimensions: 255 x 10 mm (OD = Overall Diameter)
Above is most configuration for 2002 A6 Audi 2.7t but if anyone looking into buy aftermarket. First find out the PR Code from the Audi Manual.
About PR Code:
Audi may install different parts on the same model and there is no way to tell which parts were used by the year and model alone.
Fortunately this is easy to determine with the vehicle's PR code. PR codes are 3 character alphanumeric codes that describe various options the car has. The PR codes, along with the engine code, transmisson code, etc, may be found on the vehicle's build sticker.
See the attached picture for sample PR code.
Thanks,
Gajen
[IMG]local://upfiles/12009/471A515204364D23AAB9F24FFA806853.jpg[/IMG]
Old May 11, 2006 | 11:48 AM
deez617's Avatar
auto zone sells them here in ohio.
adamsrotors
Jun 25, 2015 02:10 PM
adamsrotors
Jun 25, 2015 02:06 PM
Wicked6
Jun 9, 2014 02:04 AM
ricehead
Sep 24, 2005 06:43 PM
