A6 2007, speaker wiring non bose amp
hi
I am trying to add aftermarket amp & sub to audi a6 2007 NON BOSE, MMI High 2G can anyone help with speaker wiring colors/position on the amp/amp connector to tap into it and install the amp? I looked at this link but its for bose system and wiring differs from what it says here, presuming its because of bose system http://audiforum.us/threads/aufterma...audi-a6.13513/ thanks |
hi
I am trying to add aftermarket amp & sub to audi a6 2007 NON BOSE, MMI High 2G can anyone help with speaker wiring colors/position on the factory amp/amp connector to tap into it and install the aftermarket amp/sub? I looked at this link but its for bose system and wiring differs from what it says here, presuming its because of bose system http://audiforum.us/threads/aufterma...audi-a6.13513/ thanks |
Had no response here but had some luck and got the sub/amp working now
here's the wiring details if someone is looking to add aftermarket sub / amp to a non-bose system in audi a6 32-pin connector 1 - +12V (terminal 30) 2 - Earth (terminal 31) 3 - Bass loudspeaker front left (+) 4 - Bass loudspeaker front right (+)6 - Door loudspeaker front left (+) 7 - Door loudspeaker front right (+) 8 - Door loudspeaker rear left (+) 9 - Door loudspeaker rear right (+) 15 - Bass loudspeaker front left (-) 16 - Bass loudspeaker front right (-)18 - Door loudspeaker front left (-) 19 - Door loudspeaker front right (-) 20 - Door loudspeaker rear left (-) 21 - Door loudspeaker rear right (-) 23 - Microphone for J507 (+) 25 - Analog input (+) 27 - Loop break diagnostic wire 28 - Microphone for J507 (-) 30 - Analog input (-) the procedure is listed on the link below for bose system and there are some helpful images to guide your installation, I followed it but tapped into wires as per above details due to non-bose system http://audiforum.us/threads/aufterma...audi-a6.13513/ I did it and in business now. It took me 5 hours to do the job had to do it twice because the crapy snap-loc connectors from maplin didnt work and had to use the old fashion cable stripping to tap in, so if you lucky, you may be able to finish under 3 hours |
thanks for the really useful info m8!
I'm planning to update audio system as well If I'm not mistaken Audi stock stereo consist of 3 way components on front doors do you know which way are they wired? if mids and tweeters wired on one channels and separately subs? |
