A6 3.0 timing belt break/compression
I had a water pump lock up and eventually demolish the idlers and strip the timing belt. Has anyone had a belt break that DIDN'T bend valves? I positioned the #1 cam lobes upward, put a hose in spark plug hole and blew as hard as I could and lost no pressure. I repeated this on all holes on that side and still couldn't blow through to intake or exhaust. So, my question is...If a valve is bent shouldn't I be able to blow past it into the intake manifold or exhaust?? Does the throttle body close off so tight that I cant blow past it?
Any ideas???
Any ideas???
Unless you have Superman's lungs, you won't be able to build enough pressure to give a definitive answer to your question "did I bend my valves" using lung power alone. Good idea, though, and an indication that you may be alright. You need a leak down tester to do the job right.
But, yes, you can break a timing belt and not bend valves but this rarely happens, I hope you are one of the rare cases.
Good luck,
Bob
Good luck,
Bob
OK it gets even more interesting. I performed a compression test and had almost nothing on 5 out of 6 holes so I removed all timing components and began to test compression by rotating cam lobes upward and testing every hole. Same thing. almost no compression. So at this point I'm pretty sure I bent the valves. So after getting over about 3 weeks of bad attitude I pulled the heads and what did I find? nothing! All valves are straight as can be. I had the valves checked at the machine shop and everything is good. Anybody have any ideas as to why I lost compression? My thoughts are I let the engine sit too long and the valve carbon may have solidified. I know the air was escaping past the valves because I poured alcohol down the head at the intake valves and I could blow through the sparkplug hole and watch lots of bubbles come out of the valves.
cschema
Jun 4, 2020 02:59 AM
Audiguruforyou
Sep 20, 2011 01:31 AM
Jeffla
Jan 3, 2010 04:43 AM
fritz
Aug 12, 2007 02:55 PM
