A6 99 cruise control problem, help!
Old Aug 27, 2009 | 12:31 AM
vrso2's Avatar
muheheh, i'm back alive heheh with car as well
OK, CC work's great !!!
Old Aug 28, 2009 | 01:33 AM
a6hcw's Avatar
If resoldering does not work on cruise control module 4D0907305, then you could have a bad power transistor T7 (ST #BD535), which is located next to a large electrolitic capacitor and is embedded in white mastic material. This transistor is available from www.digikey.com where you may download a datasheet.
http://search.digikey.com/scripts/Dk...=497-8437-5-ND
Old Sep 19, 2009 | 01:30 PM
philippians's Avatar
cruise control fixed!! Thanks!!
Old Apr 19, 2010 | 02:03 AM
freakaftr8's Avatar
Member
If in fact this power transistor goes bad, this is probably the intermittant issue many of us face with our cruise control systems, like my 1999 A6Q, the cruise cuts out around 25 minutes of driving. The transistor overheats due to lack of cooling most likely due to not enough thermal transfer grease behind it backing it to the heat sync. Im going to check this out tomorrow.
Old Jul 1, 2010 | 05:45 PM
Theiceman's Avatar
can someone tell me hopw to get to the cruis control module on my 2000 A6 ? took the glove box out but no sign of it .. i know it is in their somewhere ...
Old Jul 1, 2010 | 09:20 PM
nm3210's Avatar
Uhhh, it should be right there on a little bracket:
Old Jul 1, 2010 | 10:55 PM
Theiceman's Avatar
I must be missing someething because I have an air bag there .. and if the airbag went off I would be wearing that braket .. on my Audi 90 they moved it to under thq back seat .. does anyone have a digital pic of this ? i would be more than happy to post a pic of my glove box area .. I simply have one crumple zone at each side, and above the hole for the glove box is the air bag.. this is very frustrating as I know exactly what it looks like and what I am looking for ,, i just can't see it ..
Old Jul 2, 2010 | 12:27 PM
  #18
nm3210's Avatar
Okay, here is where it is supposed to be. Keep in mind that if you have a very late model 2000 (which is more like a 2001) than I believe they got rid of this module and integrated it into the computer (w/ vac systems). If that's the case then you either have a stalk problem (thing on steering column) or a vac leak somewhere.
Old Jul 2, 2010 | 10:29 PM
  #19
Theiceman's Avatar
oh . no ... i don't think i missed that .. so i think it must be integrated as you mentioned .. that is bad news i think ..
but .. I will check again and take it aprt again since you hve gone this far to help ..
Thanks
Old Nov 29, 2011 | 02:54 AM
  #20
bigdadi's Avatar
The 3 we look at in the board may not be red color
quattroworld.com Forums: D2 A8/S8 (1997 - 2003)
