a6 blinker problem
Old Dec 20, 2006 | 07:50 PM
plusinfinit's Avatar
Default a6 blinker problem
I am cluieless on this one. I have a 99 a6 avant, my left front blinker/marker light does not liht up at full potential. It also blinks much more rapid than myright blinker. They blink at the same rate wnhen on hazards though. I took the bulp and its plastick socket out and i tested the contact points on the plastic socket and all seme to have continuiy. I have noticet a burn mark on one of the contact points and i cleaned it away but no help. The crazy light bulb just wount light as bright as the other and i don't see any evidence of a burned light bulb.
Does anyone know what is going on?
Old Dec 21, 2006 | 12:12 AM
dankhound's Avatar
Default RE: a6 blinker problem
Replace the burned out socket.
Old Dec 21, 2006 | 12:28 AM
I will do it ...but the socket has continuity...so i think it might be ok..or no?
Old Dec 21, 2006 | 01:58 AM
yamie's Avatar
bad ground?
Old Dec 21, 2006 | 02:15 AM
enjoey's Avatar
I had a similar problem on my other car. Usually it happens when the bulb's blown. Try replacing the bulb. Thats whatI did and it was fine.
Hope this helps.
[IMG]local://upfiles/28313/9BB48B2CFDB34EBCA183C04E24D4A955.jpg[/IMG]
Old Dec 21, 2006 | 04:46 AM
AWDaholic's Avatar
Senior Administrator
You're obviously low on Blinker Fluid
Old Dec 21, 2006 | 01:09 PM
madridlover's Avatar
Add a dab of solder on the burned part of the bulb socket. Sometimes they burn down causing the signal to arc across which produces the fast blinking. A dab of solder will fix the blinking problem.
Old Dec 23, 2006 | 12:39 AM
dankhound's Avatar
Think of the burned spot as a restriction in a hose. It flows electricity but not as much as it should.
XmiroxX81
Feb 2, 2012 11:09 PM
sntemp
Apr 6, 2008 03:44 PM
duburban
Jan 18, 2007 06:31 PM
18T
Oct 16, 2005 01:35 PM
mhiest
Jun 16, 2004 08:06 PM
