A6 C4 questions
Old Mar 31, 2014 | 04:28 PM
NewbornAudilover1967's Avatar
Talking A6 C4 questions
Just got this 97 2,6 Avant automatic.
There are no lights to show what the gear lever is in.
Not on the dashboard or close to the gearstick
Are these bulbs easy to replace ?
Any answer in this topic is highly appreaciated
Old Mar 31, 2014 | 11:02 PM
ManyAudis's Avatar
The lights are in a vertical line to the right of the speedo and fuel gauge and to the left of the clock. I believe there is a small reed light or lights behind the indicator. They can be replaced by removing the instrument cluster. There are numerous how to's on quattroworld. Done read the Bentley, they tell you to remove the steering column. This is not necessary. The bulbs are available at Radio Shack for a couple dollars. I recommend you replace all of the dash bulbs when you remove the cluster.
mblayton
Jan 7, 2010 07:35 PM
playboy00786
May 31, 2008 06:37 PM
zchb9
May 20, 2006 01:29 PM
portwolf
May 18, 2006 03:27 PM
VolcanicBlackA4
May 18, 2006 02:11 PM
