A6 fuel filter bolt (pic)
Old Apr 30, 2008 | 07:43 PM
rh1231979's Avatar
Default A6 fuel filter bolt (pic)
I have never seen a bolt like this with this type of spline before. Does anyone know if it takes a specialty tool to remove (Audi specific) or where to get one? It doesn't look like a regular torx.
[IMG]local://upfiles/52629/527949F1CE1744C883CE265A4916C1F2.jpg[/IMG]
Old May 1, 2008 | 08:17 AM
bob martin's Avatar
Default RE: A6 fuel filter bolt (pic)
It's a 12 point internal spline. A Torx will work in it. You can get an internal spline set at any import auto parts store or large, well stocked all lines parts store.
Or, just use a pair of vice grips on the outside....
Bob
Old May 1, 2008 | 04:38 PM
catdog's Avatar
Try a hex, I'm pretty sure that's what I used.
Old May 2, 2008 | 02:49 PM
hxgaser's Avatar
ORIGINAL: bob martin
Bob
Also known as triple square bit... It has "M" designation infront of the size. I think the fuel filter one is M10. Similar example for a torx bit would be T-25 and etc.
Old May 3, 2008 | 08:10 AM
Cmoney's Avatar
I used a hex also. If someone has already changed the filter, the bolt and the nut on back may be stripped as was the case with mine. A lot of people said the same thing. You can't get anything on the back to hold it because the space is too tight. I had to get a screwdriver to put some tension on the band and just get it loose enough to work the filter out. Make sure you have a lot of rags or newspaper on hand. The system has a lot of pressure on it and gas will go everywhere. I also took the fuse out that controls the fuel pump. Good luck with it. It won't be bad at all if your hex bolt isn't already stripped.
skihigh2299
Oct 11, 2015 05:54 PM
skihigh2299
Sep 25, 2015 12:09 AM
DJmart
Aug 3, 2013 11:08 AM
ironman
Apr 16, 2007 03:53 PM
