A6 Quattro 3.0 V6 - transmission problems
Old Nov 1, 2010 | 11:19 PM
lexinn's Avatar
Default A6 Quattro 3.0 V6 - transmission problems
I got the Check Engine light on a cupple of days ago , arond the same time theees things starded happening , i have been reading and it seams to me that this could be a --Torque converter-- Starting to fail
the first time ever the ligth came on was when Thing Number 2 Happend
Number 1-flooring the car from first gear using the tiptronic - in second gear at 2600-3000rpm i get a small (lag) a smooth lag, just not accelerating like usuall
Number 2- some times when stopping the car from maby 40mph (60km) or any speed, in drive -D- at, and when you come to a stop the RPM start flikker down to maby 400-RPM like the car is going to Stall , but then the RPM return to normal
Number 3- Also only happening some times when i put the car into Nutal -N- The RPM start to Bouch maby from 600 - 1000 RPM and if i press the acceleration pedal a little bit , it seems to go away
-just to know the gear chancing is wherry jerky sometimes
Old Nov 1, 2010 | 11:46 PM
lexinn's Avatar
relpy
Old Nov 2, 2010 | 10:21 AM
bigdadi's Avatar
Go to specialized Audi independent garage to change the tranny fluid + filter if you didn't have it changed and the car is 8 years old or 60-80k miles. GF the tranny maker recommends that to prolong the tranny life. Ask the garage to scan your car w/VAG-COM which is best tool to find out how healthy your car is.
Maybe a tranny service will get rid of the above.
Old Nov 2, 2010 | 12:05 PM
lexinn's Avatar
i did that maby 500km ago , i got the filters and oile cleand , the garage told me that there was all kinds og crap in there, but hit has not got any better
Old Nov 2, 2010 | 12:40 PM
bigdadi's Avatar
The question is general repair garage or garage specialized in Audi or Audi dealer. I suspect if general garage they didn't use same procedure & specific fluid required. It takes more than 2 hrs to perform A6 tranny svc.
http://www.zf.com/na/content/media/u...s/5HP19FLA.pdf
http://www.shinseiauto.com/japanese/...tzf5hp1904.pdf
http://www.e46fanatics.com/pdf/BMW-E...insideview.pdf
Remanufactured Audi Tranny ...
http://www.audipages.com/Tech_Articl...udiProgram.pdf
Old Nov 2, 2010 | 01:39 PM
lexinn's Avatar
.. yeas i see but still this started happening when i got i back from them , the cleaning of the transmission took a long time , they are not expterts at audi but they are experts at Mercs
Old Nov 2, 2010 | 03:12 PM
nemohm's Avatar
If everything started after the transmission "service" was done - there is the answer - the "service" was not performed as required.
Getting the car back might not do anything good; take it to an Audi shop that has experience with transmissions (most shops stay shy of even touching the transmissions).
What ATF was the one used at the Merc shop?
But if there are permanent damages - will the shop cover them?
Bottom line - get familiarity with problem - into details - read the info provided on the forum - numerous long threads.
Old Nov 2, 2010 | 06:35 PM
lexinn's Avatar
I am Taking the car to the Audi Dealer tomorrow and they are going to chek this out , if they say anything that may lead to what ther merc shop did then i will talk to them , since i payed the merc shop under the table , there are no records of the car ever being there but i doubt it will be a problem since they are easy to deal with
Old Nov 2, 2010 | 07:13 PM
bigdadi's Avatar
Undertable? Maybe you want to save money and they go cut corners.
Old Nov 2, 2010 | 07:35 PM
lexinn's Avatar
under the table means i don't pay tax and i did that after the work was done
anyways anyone have any ideas ?
