AudiForums.com
-   Audi A6 (https://www.audiforums.com/forum/audi-a6-9/)
-   -   A6 tachometer issue (https://www.audiforums.com/forum/audi-a6-9/a6-tachometer-issue-36405/)
dph138 Jul 13, 2006 03:42 PM
A6 tachometer issue
All,
I have an 2000 Audi A6 2.7T. As I accelerate, the tachometer needle will slightly jump and fall 50-150 RPM while I am in the same gear. It is little more than a nuisance, and I can't actually feel the difference when the engine revs but it makes me a little uneasy. I have been having an issue in first and second gears primarily.
I had the spark plugs, fuel filter and air filter replaced, but it did not take care of the problem as I had hoped. Any thoughts??
Thanks in advance.
-D
techbod Jul 13, 2006 04:17 PM
RE: A6 tachometer issue
check the wiring on the VSS sensor for damage and ensure connector is clean
dph138 Jul 14, 2006 10:56 AM
avant80@2.6,
I am fairly new Audi owner. This may be stupid, but what is a VSS sensor and where is it located, any help would be appreciated. I would like to check your suggestion ASAP.
Thanks,
-D
