ABS and ESP lights
Old Jan 28, 2008 | 12:58 PM
SLINEA6's Avatar
Default ABS and ESP lights
These both came on so far twice since I had the car, and went off twice, i haven’t seen it in weeks, took it to the dealer. The dealer stated he doesn't want to invent anything if it doesn't come back with anything. They ran VAGCOM, they found nothing. What does it mean when they both come on and then go off? I start to think something is failing and i have 45000 on the car and want to get it in before the warranty runs out to repair the possible future problem..
Old Jan 28, 2008 | 02:01 PM
ppgoal's Avatar
Default RE: ABS and ESP lights
Did they come on momentarily in slippery conditions and then go off? That's normal when the ABS is working - mine does it when I corner fast in snow and slide a little.
If they came on and stayed on, you have a problem brewing. However, I would not worry about it until the indicator stays on for good. Then you should get the bad news from your dealer. By the way, the ABS unit is re-buildable at a much lower cost than new.
Old Jan 28, 2008 | 02:10 PM
SLINEA6's Avatar
I think first time was in slippery conditions (some snow and sleet) but the second time It just came on when I was at a stop light. I remember the first time we just turned the car off when we saw this and turned it back on and it was gone. Not sure what to think but I hope it doesn't become anything serious, thanks!
Old Jan 28, 2008 | 08:02 PM
bsharp8's Avatar
Check your brake lights and see if they're lighting up. Mine was doing the same thing and it turned out to be a bad brake light switch. That's why the warning lights are coming on when you stop. It might be a cheap fix. The switch is $30 or $40 from the dealer.
Good luck.
Old Jan 28, 2008 | 08:42 PM
leftyturner's Avatar
A new brake light switch solved my problem.
Old Jan 29, 2008 | 02:58 PM
SLINEA6's Avatar
AHH i see, i haven't checked my brake lights, the switch could be going bad or failing, thanks!
Old Jan 29, 2008 | 03:21 PM
muphasta's Avatar
I had the same issue when I first got my car in Aug of 06 (car is an 03). The switch was the issue.
Old Jan 29, 2008 | 05:30 PM
rmknox's Avatar
If the brake switch replacement doesn't work I think your ABS module is beginning to fail. It sounds just like mine when it started to fail on my wife's98 A6 Quattro 2.8. It was intermittent at first but progressively became worse. At this point you can monitor it and note if it fails (lights on) for longer periods and more often. If that's the case I'd get it to the dealer before your warranty runs out. It's not an inexpensive fix if the dealer does it out of warranty. I fixed mine (out of warranty) by removing it myself and sending it to www.modulemaster.com where it was repaired for $200. A local shop quoted me $1400 for a new module installed.It works fine now and my total cost was $257.50 (repair and postage) and a few hours of my time removing and installing the part. There are verygood instructions on the Module Master website.
Old Jan 29, 2008 | 10:20 PM
If your module is going bad and if it's the newer Bosch version, it'll take $300 +shippingfor Module Masters to fix it.
Old Jan 30, 2008 | 11:48 AM
SLINEA6's Avatar
Great! thanks for the info.
