adjusting ignition with wagcom
Old Aug 27, 2009 | 04:18 PM
beemerfanatic's Avatar
Default adjusting ignition with wagcom
how do i do it?
tnx!!
Old Aug 28, 2009 | 12:21 AM
Jackmup's Avatar
You can't the Vag-com is more of a diagnostic tool. Download Bosch Unisettings on-line somewhere. You can adjust fuel trim, timing angle, torque, idle, enrichment...
Download;
http://www.unitronic.ca/UNISetting.php
Old Aug 28, 2009 | 02:01 PM
tnx for that! have you tryed it out?
Old Aug 28, 2009 | 05:38 PM
Jackmup's Avatar
I've used it. but if you choose to set the idle high beware you only have one shot. These effin computers learn and will block you from doing certain things. So I raised my Idle it was nice and lost a lot of vibration but I changed again one day and now I can't change it the computer won't let me. These cars are alive you know... ALIVE...
Old Sep 5, 2009 | 04:06 PM
OK! :-P
i have now downloaded the program,installed and watched it.. out of what i could see om the wagcom program,the timing is not off on all cylinders.. this program seems to change all,not one.. can it be bad coils or something? the car has traveled 280 000 km.. its not 100% stable on the idle to..
the car is not acting right.. let's say i have it in 3 gear,climbing up a hill or something.(it feels stronger when it got some resistanse if you know what i mean..)
the taco is around 15-2000 rpm,the engine is acting strangewhen i hit the pedal to the metal,not smooth like it should.. it's like somthing is wrong with the ignition.
Old Sep 5, 2009 | 08:36 PM
Jackmup's Avatar
Here are some ideas;
Check your vacuum lines, look for leaks/broken hoses.
Check your PCV lines, see this thread; https://www.audiforums.com/forum/sho...d.php?t=137362 he found some nasty crap in his lines.
How old is the Timing belt? Does it have slack due to age?
You have chain driven cam adjusters. something could be messed up there.
Try cleaning the MAF sensor.
Try adjusting the throttle valve angle.
check your injectors, maybe they are getting dirty.
Old Sep 6, 2009 | 01:13 PM
the vacuum lines are new,the timeingbelt i new. everything is new under the car,the engine/trans mounts are new too.the chaintensioners are ok.
MAF sensor stands for? (i'm not so good at english:-P i'm norwegian you know!lol.)
how do i check the injektors? never done that before..
adjusting the throttle valve angle how?
how do the car act when the pcv lines are plugged?
thanx for your help!
beemerfanatic
Sep 29, 2009 09:01 PM
beemerfanatic
Sep 11, 2009 07:33 PM
nrowensby
Jun 4, 2008 08:57 PM
Optical Serenity
Nov 11, 2006 06:31 AM
rons01a4
Apr 26, 2006 11:25 PM
