advice on buying a 2000-2002 A6 wagon?
Old Nov 17, 2005 | 02:35 AM
timfahy's Avatar
Default advice on buying a 2000-2002 A6 wagon?
I'm looking it to buying a used A6 wagon. There is a 2001 Quattro wagon 2.8 in my area with 74km in good condition for $14k. Does this seem like a reasonable price, and what should I look for in the line of things that will need to be replaced soon? How long so the exhausts last? The timing belt will need to be replaced soon. I'm a decent mechanic and I'm wondering how tough a job it is on this vehicle? What else might probably need attention soon that is going to cost me some coin? I'm new to Audi's and any advice would be much appreciated.
Old Nov 17, 2005 | 03:50 AM
dankhound's Avatar
Default RE: advice on buying a 2000-2002 A6 wagon?
The timing belt isnt too bad. You will need a cam bar to get the cams lined up again. Personally i think its the easiest of the timing belts to do. As far as comon problems- tie rods, upper links, cam seals leaking oil, dis in instrument cluster going out, drivshaft seals leaking. How long an exhaust last depends greatly on where you live. Dry and warm, maybe forever. Cold and wet, maybe a couple years. As far as price i would check a book value somewhere, and compare to other cars in area for sale and maybe some cars on the internet.
Old Nov 17, 2005 | 03:51 AM
techbod's Avatar
if your a mechanic the make of the car means nothing, timing belt is simple enough on the A6 and pennies if you do it (I will post data if required)
Old Nov 17, 2005 | 07:41 PM
karguy427's Avatar
I've got a 2000 A6 Avant W/ around 80K miles on it. Picked it up in August '04 when it had 68K on it - paid $14K + T/L.
Still need to do my belt, but I don't rust my mechanical abilities enough to do it myself.
Where are U at?
I'm in So Cal.
Let's keep in touch
Old Nov 17, 2005 | 08:07 PM
techbod's Avatar
I'm in the United Kingdom but thats like next door on the internet
betyouaint
Mar 30, 2010 10:11 PM
jzmuda
Mar 18, 2008 12:05 AM
osirus1144
Jul 28, 2007 08:10 AM
hilliard55
May 1, 2006 03:16 PM
Townshend2372
Oct 19, 2004 12:37 AM
