All oil poured out??? help!
Old Jan 17, 2009 | 08:40 AM
BrittAudi96's Avatar
Exclamation All oil poured out??? help!
I'll tell you the story first about how i noticed most of my oil was gone. I was driving to work when the oil light came on. I thought maybe i took the corner to quick cause it does that sometimes. but when it kept going off i knew something was wrong so i drove it back to my house. The engine sounded like a trunk engine so i knew that i was going to hurt it if i kept driving. So when i got to my house....about 3 quarts of oil was on the ground.
So now i am here to get help about what could have went or happened to have all the oil just pour out?
im thinking the oil pump but i dont really know.
im hoping its not to expensive and hard to fix.
please help!
Old Jan 17, 2009 | 11:51 AM
auditech79's Avatar
You probably cracked the lower oil pan, i have done it on my S4 (2.7T) when i bottomed out the pan just slightly going up a steep hill. If you take the belly pan off you will probably find a very small crack in the pan. Easy fix.
Old Jan 17, 2009 | 02:10 PM
Coors's Avatar
Oddly enough, I just experienced this with my Infinity QX4. I had Jiffy Lube change the oil. I wake up the next morning and back it out of the garage to find about a quart and half of oil on the ground.
Turns out they never tightened the drain plug. Better that than them stripping the damn thing.
Check your drain plug
Old Jan 17, 2009 | 07:56 PM
nemohm's Avatar
You must be happy, as there are stories about draining the transmission and filling up the engine;
Or filling up the engine with ATF;
There is a plenty of info on the Internet, just spend time to research.
Old Jan 18, 2009 | 10:33 AM
a6hcw's Avatar
Running an engine without oil pressure will destroy it, so you should have had the car towed home or to a repair shop.
Old Jan 18, 2009 | 05:59 PM
i actually did get it towed back to my house. Sorry i forgot to put that in. But im bring it to a garage to look at it myself. I hoping that its a simple fix like the drain plug.
Thanks everyone.
Old Jan 19, 2009 | 07:32 AM
bob martin's Avatar
"The engine sounded like a truck engine" sounds like you may have run it a bit too long without oil. You might be OK if you were running real good synthetic oil, but if you were running mineral oil, OUCH!!!
Good luck!
Bob
Old Jan 19, 2009 | 10:32 AM
Is the oil cooler ever a culprit of a oil leak or the gasket????? cause i looked at it yesterday and it seemed the oil was dripping from that.
Does anyone know why the 1996 models kinda fell off the face of the earth??? i try to find things on the internet to help me but there really isnt anything.
Old Jan 19, 2009 | 06:07 PM
A62TURBO's Avatar
That sux, do you have enough money saved up for a new car?
Old Jan 19, 2009 | 06:23 PM
oc_audica's Avatar
x2... happened to me twice
